Difference between Close and Close Project in After Effect's File menu
Sebastian Lee
on Feb 8, 2013 at 2:50:23 pm
What is the difference between Close and Close Project in After Effect's File menu
Zach Meissner
Re: Difference between Close and Close Project in After Effect's File menu
on Feb 8, 2013 at 3:00:39 pm
'Close' will just close the comp window in the timeline viewer. 'Close Project' actually closes the file you're working on and gives you a blank slate.
http://www.lab316.com
Vishesh Arora
on Feb 8, 2013 at 5:40:15 pm
Sebastian
To add on what Zach ahs said:
"Close" option will close the composition and has a shortcut key " Cntl + W". If you press " Cntrl + Alt + W ", All the composition from the Timeline will be closed.
I use this shortcut when too many comps and pre-comps are opened in Timeline just to clean up and then open only the required one.
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
2011 3D Demo Reel:
