Scripting: Add loopOut() Expression to a selectedLayer with a script?
Brandon Smith
on Feb 6, 2013 at 2:18:21 am
I am beginning to learn scripting, so I am starting off with some simple shortcut scripts. One that I am having a hard time trying to make is a script that will apply the loopOut() expression to the Position property of the layer that I have selected (or multiple selected layers). This layer already has the necessary keyframes to let the loopOut() expression work.
Any help is greatly appreciated.
Brandon
Vishesh Arora
Re: Scripting: Add loopOut() Expression to a selectedLayer with a script?
on Feb 6, 2013 at 9:55:24 am
Brandon
You will get a better answer at Adobe After Effects Expressions.
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
2011 3D Demo Reel:
Xavier Gomez
on Feb 6, 2013 at 1:36:03 pm
Assuming that :
1- your script has already identified the layer (let's call it theLayer),
2- your script has a string variable (called say expr) that contains the expression text,
you can go on like this:
var prop = theLayer.transform.position;
prop.expression = expr;
prop.expressionEnabled = true;
if you want need your script to read the property's values at a given time t, it is like this:
- for pre-expression value: prop.valueAtTime(t, true)
- for post-expression value : prop.valueAtTime(t, false)
Brandon Smith
on Feb 6, 2013 at 5:42:54 pm
Thanks for the response Xavier
Here is my code that I am currently working with, but it keeps crapping out when it gets to the actual expression. Any ideas?
var myComp = app.project.activeItem;
var myLayer = myComp.selectedLayers[0];
var prop = myLayer.transform.position;
prop.expression = "loopOut("cycle")";
