No Change when Adjusting Z Position
Randy Rubin
on Feb 5, 2013 at 8:57:10 pm
Hi All,
I'm trying to do a very simple animation of a layer with a thick line from illustrator. I want to adjust the Z position so that it looks like the line is landing on the composition from above.
I've done this effect in previous projects without issue but for whatever reason when I adjust the Z position nothing happens. All layers have 3D turned on. There are some pre-comps as well, but everything has the 3D enabled.
Any help appreciated.
Tudor "Ted" Jelescu
Re: No Change when Adjusting Z Position
on Feb 5, 2013 at 9:13:51 pm
Are you by chance looking at the preview through the Front View and not the Active Camera
Tudor "Ted" Jelescu
Senior VFX Artist
Randy Rubin
on Feb 5, 2013 at 9:28:53 pm
Yep lol. I knew it was some simple mistake. Thanks.
