Text effect plugin
Esky Ching
Text effect plugin
on Feb 5, 2013 at 3:35:37 am
Hi all,
To make the text effects, any plugins to use?
e.g. 0:26, 0:39
I can manually key all that but just want to save a bit of time.
Thanks.
Dave LaRonde
Re: Text effect plugin
on Feb 5, 2013 at 4:02:08 am
What plugins?
There isn't anything I saw that couldn't be done with After Effect as it is!
You just have to LEARN how to use After Effects, and there is no plugin that will do that for you. There isn't a creativity plugin, either...
Dave LaRonde
Former Sr. Promotion Producer
Esky Ching
on Feb 5, 2013 at 4:18:09 am
ok. thanks. i know how to do all that. just want to save time and be lazy in rush production.
Tom Daigon
on Feb 5, 2013 at 5:43:55 am
AE has TONS of Text Animation Presets. Once you learn how to use them you have a wide choice to select from. Or you can alter them to fit your needs. But you must learn how to use AE first.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid
Tudor "Ted" Jelescu
on Feb 5, 2013 at 9:23:41 am
You can benefit from a variety of Animation presets, not just the text ones but a variety of others. Combine, adjust and use layer animation as well. However, as it was pointed in the previous posts, learning the craft is essential. You can find a large number of tutorials on the net. Also, you can find many examples of great type animations that you can try to replicate once you build basics skills.
Tudor "Ted" Jelescu
Senior VFX Artist
Todd Kopriva
on Feb 5, 2013 at 11:53:39 pm
Here's information about text animation, including text animation presets:
http://helpx.adobe.com/after-effects/using/animating-text.html
After Effects team blog
