Should Collapse Transformations affect Time Remapping in Nested Comps?
Matthew Gadbois
on Feb 4, 2013 at 6:33:04 pm
I'm working in CS6 (11.0.0.378) and I have a Comp called "Timed" that contains layers with Time Remap enabled. That is nested into another Comp called "FX" where I have some effects applied as well as the Screen Blending Mode. Then the "FX" Comp is nested into a "Final" Comp. I want to toggle Collapse Transformations for the "FX" layer in the "Final" Comp so that the Screen Blending Mode works on layers below FX as well. However when Collapse Transformations is toggled ON, all the Time Remapping comes out wrong. This feels like a bug, but can anyone confirm that?
~Matt
Vishesh Arora
Re: Should Collapse Transformations affect Time Remapping in Nested Comps?
on Feb 4, 2013 at 9:20:08 pm
Matthew
I have tried the same procedure in CS3 version and there is no issue. Check the file below:
5375_collapsetransformationtimeremap.zip
If it is not working correctly in your current CS6 version, Go for the updates:
After Effects CS6 (11.0.2) update
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
2011 3D Demo Reel:
Todd Kopriva
on Feb 8, 2013 at 12:44:16 am
As Vishesh says, you need to install the 11.0.2 update.
After Effects team blog
