Card Flip in After Effects
Artem gummed
on Feb 3, 2013 at 10:55:41 am
Hi everyone I would like to make a similar card flip like you see here in the video
My problem is the front picture and the back picture. I dont know how the best option to put 2 different pictures on the back and on the front of a card. The card will be a very slim paper. I tried to put 2 pictures very tight so the distance between was 0.1 px. It worked for a rotation, but when im adding another picture under that card, some problem occur (when I flip the card to make visible the picture under that) and I have to go up to 1px to get rid of that problem
I can make a video to show you guys what do I mean
any help ?
(sorry for my english)
Roland R. Kahlenberg
Re: Card Flip in After Effects
on Feb 3, 2013 at 7:33:10 pm
In an ideal setup, you would set up the cards as per your description then Parent the back layer to the front layer.
What is the problem that occurs when you flip the two layers?
Cheers
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7)
Vishesh Arora
on Feb 4, 2013 at 9:45:52 am
The explanation is quite vague.
any help ?
This would solve the issue. Make a video or you can upload a raw project file.
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
2011 3D Demo Reel:
Artem gummed
on Feb 4, 2013 at 10:15:52 am
ok here i just uploaded the video, so you guys can see whats going on
by the way I recently found a project very very similar to what I want to make. take a look
I want to make the same. but in each opened card will be an image/picture.
Vishesh Arora
on Feb 4, 2013 at 11:52:56 am
I have created the same thing and got the same problem. So to fix I added a 2D layer after 1st image comp and that solved the issue. The problem is related to the 3D Layer order AFAI get to know from different forums(I might be wrong).
See the example below:
5370_flipimageanimation.zip
Hide the 2D layer and the problem will occur again.
When we add a 2D layer between two 3D layers, the 2D layer creates two different 3D space. In this case the when we add a 2D layer the White Solid Layer stop interacting with the 2nd Comp layer.
Another work around is that move your white solid comp 0.1 px in opposite direction. I mean give it's position a value of -0.1 px.
These are just hit and trial method. So the approach might be wrong.
Vishesh Arora
Films Rajendra
Blog:
2011 3D Demo Reel:
Artem gummed
on Feb 6, 2013 at 7:27:40 am
thanks for your advice!
Im going to try this way
Vishesh Arora
on Feb 6, 2013 at 7:46:47 am
Glad to help
Vishesh Arora
Films Rajendra
Blog:
2011 3D Demo Reel:
Artem gummed
on Feb 6, 2013 at 1:49:37 pm
omg Im lost...
I tried lots of differents layers but cant get it right
help
heres the link of my project file
http://f1.creativecow.net/file/5383/5383_photo2folder.rar.zip
