Workflow: JavaScript => (Illustrator) => After Effects
Daniel Lap
on Jan 28, 2013 at 2:39:36 pm
I have coded a JavaScript data visualization that outputs SVG elements that are animated - in the browser - based on their data attributes. I would now like to produce a video (with a little bit of 3D and motion blur) of a set of these animations using After Effects.
1. 200 (vector) circles on a straight line.
2. Camera pans across these.
3. Circles are animated (color, radius, x and y of the circles) while camera moves
I'd preferably reuse the code for the animations but I am not sure how to go about.
Are any of these workflows applicable? And in that case, which one is better?
1. "Illustrator layers to keyframes"
I paste the SVG elements generated in the browser into Illustrator and then into AE.
Then I paste the same set of layers on another keyframe and somehow AE can figure out the tween ...
2. "JavaScript in After Effects"
I use the code to somehow script the animation in After Effects ... (Can I use external JS libs when scripting AE?)
3. "A much better alternative ..."
© 2018 All Rights Reserved
