Adding a comp created as a duplicate in the timeline panel to the project panel
Paul Roff
on Jan 22, 2013 at 4:07:38 am
If you've created a composition in the timeline panel by duplicating and changing, then perhaps changing its name... can you then somehow create a copy of of it in the project panel?
Vishesh Arora
Re: Adding a comp created as a duplicate in the timeline panel to the project panel
on Jan 22, 2013 at 9:19:49 am
Paul
If you duplicate a comp in Timeline, then its not actually a new comp. Its the same comp with the a different Layer Name. The Source Name still remains the same.
See the image below:
If you click on Source Name it will toggle to Layer Name.
So you are just duplicating the same comp with a different name.
If you want a new Comp with a New SOURCE NAME, then duplicate the layer directly in Project Panel and not in Time-line.
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
2011 3D Demo Reel:
Roland R. Kahlenberg
on Jan 22, 2013 at 2:31:43 pm
The duplicate in the Timeline can be precomposed into another comp using standard procedures. Ensure that you select the "Move all attributes ... " option in the precompose dialog.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7)
