Changing multiple Comp/Precomp settings
Jolyon Greenaway
on Jan 18, 2013 at 12:52:01 am
Hello,
Just wondering if there is a way of changing multiple Comp and Precomp settings within a project without having to go through every one manually? I wish to change all the comps sizes,frame rates and pixel aspect ratios, so that they are all the same.
Here's hoping in advance,
Jolyon.
Herbie Humperdink
Re: Changing multiple Comp/Precomp settings
on Jan 18, 2013 at 1:36:58 am
I think there is a script called global comp setter. Try searching google for it
Walter Soyka
on Jan 18, 2013 at 1:56:23 am
I'm a big fan of Christopher Green's "Selected Comps Changer.jsx" script [link]. My favorite feature is that it offers an option for extending active layers at the end of a comp when you change the comp's duration.
He's got a bunch of immensely useful scripts there -- if they help you out, please consider supporting his work via his Donate button.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
John Cuevas
on Jan 18, 2013 at 2:05:23 am
Here is Compsetter
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Jolyon Greenaway
on Jan 18, 2013 at 7:38:53 am
Brilliant!
Thanks so much. I am new to AE, so its great to have some help!
Thanks again.
Jolyon.
David Cabestany
on Mar 19, 2014 at 7:46:20 pm
I always used CompSetter up until CS6 and worked fine every time, I mostly used it only to extend the duration of the composition and the nested ones. Today I tried it in CC and found out that it's not extending all the layers in the comp and none of the nested comps.
Anyone has experienced this? Is it related to CC?
Thanks.
