Output module "ignores" sound settings
Herwig Lührs
on Jan 15, 2013 at 9:58:22 am
Hi!
I have created an output module as seen below. The "Audio Output" box is checked. Almost everytime I render a file there's no audio in the rendered video.... When I put the comp into the render queue, go to the output module setting, uncheck the "Audio Output" and chek it again, it works fine.
How can I tell AE not to ignore the settings in the first place? It is kind of annoying to have to uncheck/re-check everytime.
Anyone who knows what to do?
I am working in CS5, Windows 7.
Thanks a lot
Herwig
Output Module
Vishesh Arora
Re: Output module "ignores" sound settings
on Jan 15, 2013 at 11:25:35 am
Herwig
Can't say much about the problem but you are rendering .h264 from AE which is not recommended as .h264 uses temporal compression.
Use Adobe Media Encoder for rendering .h264 .
Try saving a Template with these settings and then render.
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
Demo Reel(3D):
Herwig Lührs
on Jan 15, 2013 at 1:22:49 pm
Thanks, Vishesh!
The final product is produced in Sorenson Squeeze anyway. What I need is a fairly small output file from AE because we produce loads of clips and the h264/mov ist about 90% smaller than the uncompressed avi we used before and saves a whole lot of disk space.
Any suggestions what output format/codec to use?
Herwig
Vishesh Arora
on Jan 15, 2013 at 1:38:25 pm
Since the Final out will be from Sorenson Squeeze, I would suggest you to render .mov with PNG Codec. This will give you lossless output with fairly small size.
Vishesh Arora
Films Rajendra
Blog:
Demo Reel(3D):
Herwig Lührs
on Jan 22, 2013 at 2:08:08 pm
Thanks again, Vishesh!
The png-Version produces also files about the same size we had before with avi. I'll play around with the formats.
Cheers,
Herwig
Vishesh Arora
on Jan 22, 2013 at 2:17:14 pm
Glad to help
Vishesh Arora
Films Rajendra
Blog:
2011 3D Demo Reel:
