Ideas on how to recreate this
Jackson Redshaw
on Jan 15, 2013 at 2:09:43 am
http://shinestudio.com/pitch-perfect-2/
I've tried using Generate>Waveform>Digital but it just doesn't look right... I can't get the bars to have square tops, or to look this clear, for example if I zoom up on them with a camera they just look blurry and horrible
I only want to recreate the first few seconds where it is the waveform by itself, not on the DJ Mixing Interface
Viktor Tornfors
Re: Ideas on how to recreate this
on Jan 15, 2013 at 4:34:38 pm
Hi!
This is easily done with shape layers. Shape layers is a pretty overlooked feature of After Effects. But very powerful.
I put together a project file for you: http://www.tornfors.se/other/waveform_cs5.aep
I created a shape layer containing a single rectangle, using the rectangle tool. Then i added some properties to the shape layer. These properties can be found by twirling down the shape layer and pressing the arrow with the word "Add:" next to it.
I added a "repeater", which just repeats the rectangle to the required amount. I also added "wiggle transform", set to only wiggle the scale.
This way it wiggles the scale of each repeated instance of the shape layer independently, creating the waveform-like effect.
The background grid is also made with shape layers.
A great site for learning more about shape layers is Mattrunks. This tutorial is a good starting point. http://www.mattrunks.com/en/tutorials/after-effects/shape-layers-sparks
22 year old motion designer from Sweden.
http://www.vimeo.com/tornfors
Jackson Redshaw
on Jan 15, 2013 at 11:45:26 pm
Hi, thanks for your reply and help! But is there anyway to make the shapes go to the music?
Jackson Redshaw
on Jan 16, 2013 at 1:40:51 am
Thanks Heaps! You're a legend! Just opened it, will do some tweaking and it will be perfect! Thanks!
Viktor Tornfors
on Jan 16, 2013 at 11:05:12 am
No problem!
If you want to make the bars move to the music, you can do that too.
Put your song into the timeline. With it selected, go up in the menu Animation - Select Keyframe assistant and press Convert audio to keyframes
You will now get a Null, called Audio Amplitude. If you twirl it down you got your audio amplitude in keyframes there.
Twirl down the scale property of your Bars-layer. (I think both the wiggle transform scale and the normal layer scale would work. Play around!)
On the scale property, put this expression:
temp = thisComp.layer("Audio Amplitude").effect("Both Channels")("Slider");
[value[0], temp];
And it will move to your beat.
You could also use the plugin Trapcode Soundkeys. It would give a better result, but it costs money.
Jackson Redshaw
on Jan 16, 2013 at 11:42:36 am
Thanks for that, I'll give it a go.
Jackson Redshaw
on Feb 5, 2013 at 6:57:43 am
Hey Again,
Is there an easy way to zoom along the waveform, having multiple text boxes on top as we fly past?
Jackson Redshaw
http://www.youtube.com/MITLRproductions
