Animating hearth rate graph(ECG).
Kex Moderc
on Jan 12, 2013 at 3:35:05 pm
So I want to make a dynamic graph projector.
This is a good example what I want to make:
http://www.ecgsimulator.net/demo.aspx
So I want to make continious projecting.
You see that the heart beat jump is always the same- only the line between heartbeats changes with the bpm.
I would like to connect it to the value of the number, that would show pulse.
You have any idea how would I do that?
Roland R. Kahlenberg
Re: Animating hearth rate graph(ECG).
on Jan 13, 2013 at 5:41:12 am
You should be able to find tutorials and AEPs by Googling.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7)
Kex Moderc
on Jan 13, 2013 at 9:24:10 am
I have looked everywhere, but there are static.
I would like, that the graph changes with the value of number, but I don' know how. Like on that site I posted in first post.
Of anyone can help please show me how. I need it really badly.
Tom Masters
on Jan 13, 2013 at 7:11:00 am
the sample you show is not really accurate to how an EKG displays heart beats.
I think that is what you are getting at with your question.
in this spot below, in the first half a second or so, it shows how an EKG measures a heartbeat.
http://hiredweapon.com/tom/index.php?/coreg-ekg/
I did some research into accurate behavior of an EKG unit.
I created the template and animatic for the spot, which was used for the finished spot.
My EKG setup also made a cameo in this spot as well.. why not re-use a good setup!
http://hiredweapon.com/tom/index.php?/tru-tv/
if this is what you are looking for, I'd be happy to explain how I built it.. very basic.
Kex Moderc
on Jan 13, 2013 at 9:51:00 am
First I must say- Great commercial:)
This ECG looks really realistic and that is what I am looking for.
But what I want is that the ECG is connected to some value, that represents bpm. So if I set the value to 60, it actualy makes one beat per second, and if I higher it to 120, there should be twice as much beats. So I am looking dynamic changing of graph connected to bpm.
I am really thankfull for helping me this out.
