Color difference key: lots of spill on talent's legs
Eric Chard
on Jan 11, 2013 at 9:12:54 pm
If you go to this site:
http://www.hollywoodcamerawork.us/greenscreenplates.html
You can DL some great great screen practice sequences in HD, free.
So, I'm struggling w/the first, the talent in the green screen stage w/the camera dollying to the right. There's a lot of green spill on the talent's legs, and while I can pull a nice key on her, her legs wind up semi-transparent.
I've addressed this by doing the best key I can w/CDK, and then duplicating the layer multiple times to build up the opacity. AFAICT, this works fine. However, it feels bush-league.
IS duplication of a keyed layer a valid workflow?
Thanks.
"Putting the HARM in 'harmonica' since 2005."
Dave LaRonde
Re: Color difference key: lots of spill on talent's legs
on Jan 11, 2013 at 9:18:58 pm
Yup, Hollywood Camera Work is a gem, that's for sure!
With the Color Difference Key, You may want to use AE's built-in Spill Supressor. Use the eyedropper to pick the precise shade of green to suppress.
Or you could use Keylight, which could help a lot.
Dave LaRonde
Former Sr. Promotion Producer
Dave LaRonde
on Jan 11, 2013 at 9:36:39 pm
Darby Edelen also posted a nifty green spill removal recipe for AE about three months ago. Here's th link:
http://forums.creativecow.net/readpost/2/1027628
Dave LaRonde
Darby Edelen
on Jan 12, 2013 at 12:57:04 am
[Eric Chard] "IS duplication of a keyed layer a valid workflow?"
Yes, but usually you'd do a separate key with different parameters on the duplicated layer to try and preserve the legs (or whatever part you happen to be working on) and then use a junk matte/mask to eliminate any issues that causes.
Most difficult keying takes some back and forth between keying and using junk mattes/masks on several layers.
Darby Edelen
