Correct presets for animation on tv
Ellen Pollard
on Jan 8, 2013 at 1:45:52 pm
Hello!
I am creating an animation video in after effects (cs5).
Now I'm wondering what the correct presets are, for tv.
At the moment I use:
HDV/HDTV 720
so 1280 x 720 px
This may be a silly question :)
If this would be shown on tv, would the quality be good enough?
Thanks a lot!
John Cuevas
Re: Correct presets for animation on tv
on Jan 8, 2013 at 2:03:15 pm
That choice will work fine, it's what use everyday(cept I change the frame rate)
One question are you just creating the animation or doing the entire post work? Cause if someone else is going to composite your animation into there work, then save yourself and the editor grief by just coordinating now. Nothing worse than creating an animation and having it not look 100% because it's being used in a comp that has to scale it/change frame rates....
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Ellen Pollard
on Jan 8, 2013 at 4:38:20 pm
Hi John
Thanks a lot for the answer.
I would just render the animation myself, into a .mov I guess?
Rendering in H264.. quicktime.
The animation would not be used in another movie.
Thanks again :)
Walter Soyka
on Jan 8, 2013 at 3:18:42 pm
I like John's advice a thread or two down to work in 1920x1080 and scale down to 1280x720 if necessary.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
