Stray DPX frames
Frederic Lumiere
Stray DPX frames
on Jan 6, 2013 at 4:31:55 pm
Anyone else experiencing stray frames in DPX?
Frames that shouldn't be there are and some that are shouldn't at the head and tales of layers?
Frederic Lumiere
Re: Stray DPX frames
on Jan 6, 2013 at 4:34:26 pm
To make matters worse, often it looks fine in the comp but the frames appear and disappear in the render!?
Dave LaRonde
on Jan 6, 2013 at 6:49:54 pm
First though: it's a frame rate mismatch.
AE defaults to importing image sequences at 30 fps. If you put such a sequence into a comp with a different frame rate, oddness ensues.
You can change the frame rate of the sequence in the Interpret Footage settings, and you can change the default interpretation in AE Preferences.
Dave LaRonde
Former Sr. Promotion Producer
