Asus n56vz laptop for After Effects?
Engin Osmanovski
on Dec 31, 2012 at 2:14:42 pm
Is this Asus N56VZ laptop a good option to work with After Effects thoroughly? (Also C4d and 3ds max...). I am giving some key specs below:
- İ7-3630QM 2.4 GHz (Up to 3.4 GHz with Turbo Boost)
- 16 GB RAM
- NVIDIA GeForce GT 650M 128Bit (4GB)
- 1TB Hdd (5400 rpm)
Todd Kopriva
Re: Asus n56vz laptop for After Effects?
on Dec 31, 2012 at 6:07:26 pm
That's a very slow hard disk drive, and that will slow down your work. It doesn't meet the minimum system requirements.
See this page for information about hardware for After Effects: http://adobe.ly/pRYOuk
After Effects team blog
Engin Osmanovski
on Dec 31, 2012 at 9:43:50 pm
What if i replace the hdd with a 7200rpm one? Still bad?
Todd Kopriva
on Dec 31, 2012 at 9:59:08 pm
That does at least meet the minimum system requirements. Follow the link that I gave to learn all about what hardware factors influence performance and how.
Suniel Kummar
on Mar 27, 2013 at 11:23:35 pm
Hi there,
Any idea why wont above configuration work even after changing the hard disk to 7200 RPM? Sorry I tried looking at the link above but can't find the reason, any help is much appreciated.
Cheers,
Engin Osmanovski
on Mar 28, 2013 at 3:57:13 pm
If i am not wrong, it will work with a 7200. Just won't work efficient/fast enough with only 1 disk. They recommend "at least" 2 (1ssd + 1hdd) internal disks for AE. (More is better). It is a matter of separating the read and write process. The more you distribute these tasks to different disks, the more performance you get.
