nasty bit of aliasing - any tips on removing it?
Dylan Hargreaves
on Dec 28, 2012 at 9:18:48 pm
Hey folks,
Please take a look at the attached still. Notice the light behind the presenter: there's a nasty bit of red aliasing off its left edge.
The footage is AVCHD natively edited in Premiere Pro and sent to AE for grading. If I can't remove it from the original footage, might transcoding the footage using an HQ compressor such as 5DtoRGB get rid of it?
Thanks in advance!
D
Dave LaRonde
Re: nasty bit of aliasing - any tips on removing it?
on Dec 28, 2012 at 9:27:12 pm
[Dylan Hargreaves] " If I can't remove it from the original footage, might transcoding the footage using an HQ compressor such as 5DtoRGB get rid of it?"
Probably not. There's a reason why 5D's are so flippin' cheap: they don't have the world's best system for recording color. Thus, the color problems are recorded right into the original files, and it will be EXTREMELY difficult -- think in terms of entire work days -- to fix them. I'm not sure how many shots this affects. So it's difficult to say for certain.
How much time do you have?
Dave LaRonde
Former Sr. Promotion Producer
Dylan Hargreaves
on Dec 28, 2012 at 11:33:39 pm
It was actually an FS700 Dave!
I do have a bit of time, but if it means removing it frame by frame I'm not sure the budget quite justifies it.
It's on a tracking shot, but I'm wondering if a cheeky bit of photoshop work might suffice...
Angelo Lorenzo
on Dec 29, 2012 at 1:24:16 am
Its hard to tell from the stills, but the channels all look a little fried. I would try tracking the object and applying a localized channel blur.
5DtoRGB may help, as I would also assume any conversion with FFMPEG/FFMBC as they bypass Apple's Quicktime elements which seem to chew up video.
Angelo Lorenzo
Need to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services - Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire - The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Dylan Hargreaves
on Dec 29, 2012 at 12:18:03 pm
Thanks Angelo, will give it a try!
