What does the triangle symbol in Info panel mean?
Sebastian Lee
on Dec 19, 2012 at 2:12:36 pm
So, what does the triangle symbol in Info panel mean? Be aware that I've searched before posting.
John Cuevas
Re: What does the triangle symbol in Info panel mean?
on Dec 19, 2012 at 2:20:51 pm
Can you post a screen grab, not seeing a triangle symbol, but the info panel does update depending on what you are doing.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Ryan Hill
on Dec 21, 2012 at 4:10:38 pm
I looked in my info panel. The only triangular thing I saw is an A for Alpha
Ryan Hill
on Dec 21, 2012 at 4:14:47 pm
Wait, after I moved something a triangle appeared.
Position: 938.0, 538.0
[Triangle]: -22.0, -2.0
That's a delta symbol, it's showing the change in position.
