3D Rotate around Circle from straight line of text
Sum Choi
on Dec 16, 2012 at 10:57:58 pm
I want to display a flat, straight line of text first then afterwards have the text evolve into a rotating circle.
I have no clue how to approach this.
Does anybody have any ideas?
https://vimeo.com/user11696429/videos
Ridley Walker
Re: 3D Rotate around Circle from straight line of text
on Dec 17, 2012 at 12:59:33 am
There are many ways to achieve this depending on precisely what you need and which version of After Effects you have. CS6 with the Ray Traced renderer allows adjustment of the layer curvature, you'd need to precompose the text first then adjust the curvature and the number of segments to taste.
Or you could use CC Cylinder to wrap the type around a pseudo 3D Cylinder that responds to camera moves.
Or you could place the type on a mask path and animate the path from a straight line to a circle as I have done here:
5094_typestraighttocurvecopycs5.5.aep.zip
CircleType
Sum Choi
on Dec 18, 2012 at 7:00:45 am
I'll give it a try when I have time. Thanks!
Vishesh Arora
on Dec 17, 2012 at 8:21:11 am
Sum
See this tutorial on how to animate text on path:
http://ae.tutsplus.com/tutorials/motion-graphics/animating-text-along-a-pat...
I have created an example of what you want to achieve:
5095_textwithroundpath.zip
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
Demo Reel(3D):
