Utilize a 360˚ VR into a video (slow motion)
Chris Mathews
on Dec 10, 2012 at 8:14:33 pm
Hi guys!
I have a client who would like to utilize a 360˚ VR into a video by making it rotate smoothly. If you're not familiar a 360˚ Object VR is a 36 image (rotated and shot every 10˚) interactive image that you can rotate.
They only need it do a quarter turn, so I am looking at using 10 images. Does anyone have any suggestions on how I could do this? It's not as simple as playing the 10 frames slower than 23.976, so I need in-between frames that don't exist.
I tried tweening in the timeline panel of Photoshop with no success, maybe I should try the Puppet tool in After Effects?
Struggling here! Please someone help!
Stefan Hinze
Re: Utilize a 360˚ VR into a video (slow motion)
on Dec 11, 2012 at 12:17:16 am
I realy try to help!
how about shoot the images you need?
don´t make 10 --> go for 30 or so!
(take a step back, to see the bigger picture)
Chris Mathews
on Dec 11, 2012 at 12:33:29 am
Hi Stefan,
I mean this with respect, but don't you think I know that? Why would I be asking for help if I could just reshoot it? It's not my images, they want to utilize something of their own.
Regardless of stating the obvious, it was nice getting a response.
Chris
Stefan Hinze
on Dec 11, 2012 at 12:38:31 am
ah ok!
now you got me thinking ;)
(in a good way)
what about Camera Projektion?
projekt the "thing" on some solids and make your camera move free.
you can only "get away" with somd smal angels, but maybe it´s enough!!?!
Chris Mathews
on Dec 11, 2012 at 12:50:02 am
"Project" it? Can you explain? It did cross my mind to try and move a camera around it, but I'm not sure how it would work. I'm still thinking I might have to "create" those in between frames with the puppet tool or something?
Stefan Hinze
on Dec 11, 2012 at 1:07:19 am
(i hope i can make my self understandebl --> not a natve english speaker)
ok, AE gives you the ability to projekt a image on some solids (white would be the color of choice)
YT gave me this as a example :
think it the other way around --> don´t mak the enviroment --> make the object (or whatever you need to visulise)
to get a tut :
or
maybe take a look at VCP / tuts / Camera Projektion
i hope i understood what you try to do!?
greetz
Stefan
(it´s 2:00am in germany... in 7h i need to get my video to the client... like always... ;) )
Chris Mathews
on Dec 11, 2012 at 1:10:42 am
Thanks man, I will take a look at these. Good luck on your deadline, I know how you feel!
Stefan Hinze
on Dec 11, 2012 at 1:28:48 am
hey,
i was working... the musik was loud... i drank my cofé ... and BAM:
check this out... if the projektion dosn´t work for you...
http://library.creativecow.net/articles/larsen_carl/cube_world1.php
Ashwin Kulothungun
on Dec 11, 2012 at 12:31:51 pm
So: you're starting with 10 images, each shot ~10 degrees apart, right, your video will end up being a panning shot across these 10 images, and you have no in between shots to make a timelapse, is that right?
Something simple:
Throw your images into photoshop and use photomerge to generate a giant panorama that you can pan across:
http://help.adobe.com/en_US/photoshop/cs/using/WSfd1234e1c4b69f30ea53e41001...
Something more involved but with more applications:
Use trapcode horizon to generate a seamless environment:
http://www.redgiantsoftware.com/products/all/trapcode-horizon/examples/#tab...
A
Chris Mathews
on Dec 11, 2012 at 12:44:53 pm
Unless I am reading your tip wrong, I don't that will work for me. Mine is an object vr, not a pano vr, therefore it is a product spinning 360˚s, shot every 10˚s
Dave LaRonde
on Dec 11, 2012 at 3:09:29 pm
[Chris Mathews] "I have a client who would like to utilize a 360˚ VR into a video by making it rotate smoothly....
They only need it do a quarter turn, so I am looking at using 10 images....
Mine is an object vr, not a pano vr, therefore it is a product spinning 360˚s, shot every 10˚s "
If you can put your hands of the shots originally used to build the VR, you might stand a fighting chance. Otherwise, the alternative is obvious: reshoot it.
Quicktime VR's aren't the most high-resolution media on the planet. They're also intended to be interactive: the user controls the motion, so the concept of "smooth" goes out the window.
Unless you're really good at rewriting code (I'm not!), I think it would take a lot of time and effort to pull of a move that won't match well with -- and look worse than -- the surrounding shots.
I think both you and the client would be a lot happier if there's any way you can just re-shoot the thing. This smells a lot like a client trying to save money on reshooting, but who doesn't realize or understand the implications of this particular type of repurposing.
Dave LaRonde
Former Sr. Promotion Producer
Tudor "Ted" Jelescu
on Dec 11, 2012 at 3:19:51 pm
You can try time remapping the 10 frames- that will create inbetween frames for you. Twixtor is another way to go - but all things considered you will most likely end up with a lower quality shot- I would also highly recommend re-shooting the product.
Tudor "Ted" Jelescu
Senior VFX Artist
Chris Mathews
on Dec 11, 2012 at 4:28:02 pm
I appreciate everyone's input and we are working with them to just reshoot it now that we can't use what they already had.
Thanks again!
