Creating an interlaced (50i) comp?
Fabio de la Rocha
on Dec 9, 2012 at 4:25:33 pm
I'm probably missing something really obvious, but help would be much appreciated.
I need to create an SD interlaced PAL comp, however there is no option to set my comp up as interlaced in the Composition Settings dialogue. I can set my frame rate to 50, but I assume this would be 50p not 50i.
This is not something I've ever had to worry about, since it's the first time I've been asked to deliver an interlaced project.
As I say, any help would be greatly appreciated.
MacPro 8Core 22GB running FCS2 / CS6 / C4Dr12
17" HiRes unibody MacBook Pro 2.66/8GB running FCS2 / CS6 / C4Dr12
Vishesh Arora
Re: Creating an interlaced (50i) comp?
on Dec 10, 2012 at 5:00:05 am
Fabio
See this:
http://forums.adobe.com/message/3910750
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
Demo Reel(3D):
Fabio de la Rocha
on Dec 10, 2012 at 5:30:10 am
Hi Vishesh,
Many thanks for your kind reply. I followed the link, but it doesn't quite deal with my issue. I am working with comps that consist of stills and assets crested within AE (text, solids etc.) and no VT. What I need to know is how to set up my comp (using the composition settings dialogue) so that I can export interlaced. For instance, do I set my comp up as a 25fps project, then select interlaced on export? Alternatively should I set up my comp as a 50fps comp and then select 50i on export?
Thanks again.
Walter Soyka
on Dec 10, 2012 at 2:17:20 pm
[Fabio de la Rocha] "What I need to know is how to set up my comp (using the composition settings dialogue) so that I can export interlaced. For instance, do I set my comp up as a 25fps project, then select interlaced on export?"
Yes. Work in a 25 fps comp, then turn Field Render on in your render queue item's render settings.
Make sure that you have turned Separate Fields on in the interpretation settings of all your interlaced footage.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Dave LaRonde
on Dec 10, 2012 at 3:53:10 pm
...and since this is SD video, you may have a problem with the field order. It can be either upper or lower-field first in PAL. It depends on the file you need to deliver, and the source video.
PAL DV and PAL D1 are both 720x576. PAL DV is lower field first, and PAL D1 is upper field first. Confusing, yes?
Dave LaRonde
Former Sr. Promotion Producer
