AE CS6 won't play ProRes 422 HQ files
Andy Murphy
on Dec 6, 2012 at 5:17:38 pm
I am new to CS6 so maybe my settings are not correct yet, but I get bad video when I import ProRes 422 HQ mov files. The same movie as an Uncompressed 8 bit is fine. I can export to ProRes, but can't seem to get it to look correct in CS6. Any help is appreciated. Thanks.
Todd Kopriva
Re: AE CS6 won't play ProRes 422 HQ files
on Dec 6, 2012 at 5:39:43 pm
See this, and tell me which (if any) of the workarounds at the bottom of the page work:
http://blogs.adobe.com/aftereffects/2010/05/prores-4444-and-prores-422-in.h...
After Effects team blog
Andy Murphy
on Dec 6, 2012 at 7:20:28 pm
Thanks for the information. Any idea if a patch is coming for this?
Todd Kopriva
on Dec 7, 2012 at 12:10:15 am
I can't answer your question without knowing which of the workarounds on that page worked for you, what hardware you're using, et cetera.
For example, if you're using AJA hardware and the problem is a conflict with AJA codecs as described on the page that I linked to, then it would be AJA that would need to provide the update.
