error message - wont accept the 'ok' click
Hope Holmesby
on Dec 5, 2012 at 2:02:00 am
Hi there....thanks for reading this....appreciate very much
Opening an AE file, and before it actually is completely opened, it shows a message that many files are not found, then it shows another message, an error message. You are suppose to then, click the 'ok' button on the error message.
I clicked ok, but the message does not go away.
"After Effects error: zero denominator in ratio multiply. (17 :: 17)"
Kept clicking it soooooo many times, and message will not go away to allow the project to completely open.
What do you think I should do?
It is happening due to proxies in the project. Have had trouble with proxies before. There is a proxy on one of the comps....I can see that as it is trying to open the project
Have tried opening all the saved versions of it, and the same thing happens. Other projects open fine.
What do you think?
Thanks so much for your consideration.
Warmly,
Hope
__________________________________________________
Life is here to enjoy.
iMac 3.5 GHz Intel Core i7, 2TB; Mac OS 10.6.8, 16 GB RAM; 2 La Cie external HDs 1 TB each; After Effects CS5.5; Sound Track Pro 3.0.1; Final Cut Pro 7.0.3; Compressor 3.5.3
Dave LaRonde
Re: error message - wont accept the 'ok' click
on Dec 5, 2012 at 2:38:59 am
Try this: create a new project, then IMPORT the problem project into it. You ought to be able to sort out the proxy problem after that.
Understand that you'll be creating an entirely new project, and that saving it won't affect the existing problem project in any way.
Dave LaRonde
Former Sr. Promotion Producer
Hope Holmesby
on Dec 5, 2012 at 2:43:08 am
Dear Darling Dave....
Wow...what a great idea...thank you soooooo much...will give it a try.
You're the best.
Thanks so much for answering....
Lots of bliss to you..
Warmly,
Hope
Hope Holmesby
on Dec 5, 2012 at 2:46:45 am
IT WORKED!!!!!
Sooooo thrilled...
You're the B E S T!!!
Thanks so much for answering....You've helped me many times in the past and I send you a big big THANK YOU.
Hope you are having a wonderful holiday season.
Warmly,
Hope
