AE Cache issue driving me crazy... sos anyone!!
Jamie Milks
on Dec 5, 2012 at 12:40:51 am
Alright, when i start AE i get the warning...
"Your disk cache folder is on a drive that does not have enough available space to safely store the full amount... blah blah blah"
I have dedicated a Samsung Pro 256GB SSD specifically for AE cache.
In Preferences > Disk Cache
I have Enable Disk Cache Checked.
Maximum Disk Cache Size: 220GB
Choose Folder... > (K:\The Samsung Pro 256 SSD)
Conformed Media Cache Folder: Choose Folder:
Database:(K:\The Samsung Pro 256 SSD)
Cache: Choose Folder:
Now... what did I do wrong in distributing the cache folders?
I am running my projects off of a Samsung 840, 512GB SSD
I also have another Samsung Pro 256 SSD that I use for Adobe PrePro Cache.
Total - 3 SSD's.
I back everything up to HDD's - Raid 1.
The SSD I'm using for AE's cache - when I checked after the warning reports the following:
Used space: 10.6GB
Free space: 227GB.
Capacity 238GB
Why is AE telling me that its getting low??
Anyone with knowledge that thinks this could be a bug just throwing me off?
or should I not be keeping all the AE cache files on that one single
SSD? Did i spread them out correctly?
Thanks.
Roland R. Kahlenberg
Re: AE Cache issue driving me crazy... sos anyone!!
on Dec 5, 2012 at 1:58:47 am
[Jamie Milks] "The SSD I'm using for AE's cache - when I checked after the warning reports the following:
Used space: 10.6GB
Free space: 227GB.
Capacity 238GB
Why is AE telling me that its getting low??"
You've set aside 220GB for AEs cache. With CS6, AE requires that you set aside 10GB free on the drive with the cache folder/files. More info here - http://helpx.adobe.com/after-effects/using/memory-storage.html.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7)
Jamie Milks
on Dec 5, 2012 at 2:08:00 am
im an idiot....
Kevin Reiner
on Dec 5, 2012 at 2:49:50 pm
We're all idiots. That's what the COW is for. ;)
Mac Pro 2 x 3 GHz 6-Core Intel Xeon
32GB Memory
Dual-channel 4Gb Fibre Channel PCI Express card
Dell Display (23" flat panel)
ATI Radeon HD 5770
AJA Kona LSi SD/HD capture card
Rourke 16 TB
Flanders 2460
SOFTWARE
Mac OS X 10.6.5
FCP 7
After Effects CS5
Boris Continuum
Sapphire Plug Ins
All Trapcode Plugs
Zaxwerks Invig
Andrew King
on Dec 17, 2012 at 6:04:40 pm
Thanks for the OP and the replies. I have one followup question.
I too have a 256 GB Samsung 840 Pro dedicated to disk cache. I'm getting the same error as the OP every time I open AE.
Originally, I allotted 200 GB. No problem.
After a couple of sessions, AE has used about 46GB.
Cue error.
I found that I have to readjust the allotted space based on available disk space (minus 10GB) every time I open AE. It seems to me that AE should know how much space it has used from all sessions. Am I making sense, and am I crazy?
Can I just ignore the error? Should I be readjusting every time? or will it make a difference?
Andrew
9.5"
CS6
Andrew King
on Dec 17, 2012 at 6:28:19 pm
(Sorry for the double post. Meant to reply to your reply.)
Cue error.
Andrew
Agent Double O Nine and a Half
CS6
David Cabestany
on Nov 4, 2014 at 4:27:13 pm
Hey Andrew,
Did you ever work this out?
I just put a 256gb drive on my machine, exclusively for Cache. I alloted 220 gb in After Effects and I'm still getting the same warning when I launch AE.
Any ideas?
Thanks.
