Cropping in AE using rulers?..
Andrew Brewer
on Dec 4, 2012 at 3:30:16 pm
Heya. Ok, so I saw someone appearing to use rulers/guides to crop off part of a layer, allowing the layer to moved and be revealed beneath it, without having to animate masks or put solids in etc. I can't fathom it - was this a dream?
Vishesh Arora
Re: Cropping in AE using rulers?..
on Dec 4, 2012 at 4:17:13 pm
Andrew
Press " Alt/Optn + ' " and " Shift + ' " to enable Proportional Grid and Grid respectively.
Press " Cntl + Shift + ' " to Enable Snap to grid.
You can crop the layer visibility by using Region of Interest Option. But this is not cropping of layer. Its only affecting its visibility.
In the same way use a mask and Toggle Off the Mask and Path Visibility to crop the layer visibility.
This will create an impression that you are cropping without any mask.
Though you have to change the Bounding Box of Mask path to change the shape.
Don't know any other option to crop off part of a layer.
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
Demo Reel(3D):
Andrew Brewer
on Dec 4, 2012 at 4:28:08 pm
Ahah, great, yeah it must have been region of interest I was thinking about. Unfortunately this applies for a whole composition so either i need to pre-comp or just do it the usual way with masks.
Thanks for the reply :)
Vishesh Arora
on Dec 4, 2012 at 4:35:41 pm
Glad I could help
Vishesh Arora
Films Rajendra
Blog:
Demo Reel(3D):
