looping effects in After Effects?
David Burns
on Dec 4, 2012 at 2:34:09 am
Hello, I was wondering if it's possible to loop an effect in after effects. Let me explain more. I'm creating a scene with changing colors, the best look for me was using the Hue/Saturation effect. I would just key frame it and change the color every 5 frames, this gives me a quick color change. The thing is, its tedious to key frame it every 5 frames for the entire clip. It would be better if I could some how loop it through the entire clip. I basically want to animate it for about 30 frames and than take that animation and loop it for the rest of the clip.
I hope I explained this well enough, if you want more information let me know, thanks for any help!
Walter Soyka
Re: looping effects in After Effects?
on Dec 4, 2012 at 4:20:39 am
Add your keyframes, then alt-click the stopwatch for the parameter. Add the following expression:
loopOut("cycle");
This will loop your frames for the duration of the layer.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
