Can I reduce the size of all parts of a Composition?
Amanda Morrison
on Nov 29, 2012 at 7:16:31 pm
Hi there,
I had to reduce the size of an animation from 1920x1080 to 480x360. Is there a way that I can move and shrink the entire animation and all its keyframes so that it fits the smaller size, or do I have to manually go in and adjust every single keyframe?
Any tips would be greatly appreciated!
Amanda
Stefan Hinze
Re: Can I reduce the size of all parts of a Composition?
on Nov 29, 2012 at 7:36:30 pm
no no no, you donĀ“t need to do this by hand!!!
Help is on the way!!!!
there are scripts that do this for you...
or
you can parrent all to a null, and scale the null down...
or
just put the 1920 comp in a new comp 480 and scale it down!!
go for the last option! benefit of that way is --> changes in the 1920 version, will be in the 480 version!!!
i hope this helps!
Amanda Morrison
on Nov 30, 2012 at 5:26:09 pm
Thank you so much!
