Exporting a tracked path
pavlonjablon
on Nov 29, 2012 at 2:49:20 pm
Hi guys,
i am looking for a way to track a movement of a hand in a clip and then to export the tracked path so I could use it in Illustrator/Photoshop. Is there any way to do that in After Effects? I am not a newbie to After Effects, but the complicated stuff like tracking have always been too complicated for me.
Pavel
Dave LaRonde
Re: Exporting a tracked path
on Nov 29, 2012 at 3:35:12 pm
A tracked path is a succession of position keyframes. It isn't a path as you're probably used to using in Photoshop or Illustrator.
It would help to know why you feel you need a tracked path from tracking data; there may be alternatives you haven't considered.
Dave LaRonde
Former Sr. Promotion Producer
pavlonjablon
on Nov 29, 2012 at 3:41:55 pm
I would like to track a movement of hands/head of a rapper from a music video, then use the path to create an info-graphic poster, displaying the movement of his limbs/head separately.
Dave LaRonde
on Nov 29, 2012 at 5:39:56 pm
Ah. If you're looking for nice curves indicating motion, I think you would be disappointed by the results of a motion track. Instead, you might want to look for extremes in motion, then construct you own path.
You can do this by locating the extremes of motion on a video layer, then highlighting them and hitting the asterisk key on the numeric keypad. This makes them easy to find when you create a solid, and make a mask with vertices at those points of extreme motion.
The resulting mask path can then be used in Illustrator or Photoshop (I think: not sure about Photoshop).
Dave LaRonde
Cassius Marques
on Nov 30, 2012 at 12:23:04 pm
What kind of variables are you representing on this info-grafic? velocity? position?
If you have it tracked you can copy the position and paste it in a mask (within AE). Then copy/paste to a path at illustrator or probably even PS.
