Twixtor pro Tracking points not working?
Mojmir Sladič
on Nov 27, 2012 at 12:09:34 am
Hello, I have a problem regarding Twixtor pro's tracking points.
I don't get any changes whatsoever in ghosting when I use them. I followed their tutorial on using them, I took the following steps, in short:
1. switch display to source
2. find the problematic frames and apply tracking points for MainBG layer (passing under a bridge, the edge was ghosting, so I used 3 tracking pts to track the edge)
3. Animate the tracking points to follow the problem edge (they are set to "Don't use" before and after I need them)
4. Switch back the display to twixtored output
Result? The exact same as before. What have I done wrong or should do?
Mojmir Sladič
Re: Twixtor pro Tracking points not working?
on Nov 29, 2012 at 2:26:00 pm
anyone :D?
Lori Freitag
on Dec 12, 2012 at 11:23:46 pm
Are you setting the point to "Main_BG Layer" when the point is in use? And repositioning them on each frame (animating the points so there is a keyframe for each frame)?
Mojmir Sladič
on Dec 12, 2012 at 11:50:25 pm
Thx finally a reply :D
But yes, BG layer is selected for points, all animated and I've set the points in SOURCE, not TWIXTORED OUTPUT
Pierre Jasmin
on Dec 24, 2012 at 6:46:03 pm
It might be easier if you sent a project (with media) to techsupport at revisionfx dot com
Or alternatively if too big hit the support button on the website so it returns to you an FTP upload zone
Pierre
