rasterize but keep position
ben wolfinsohn
on Nov 22, 2012 at 11:17:02 pm
why is it when i rasterize a comp, an object inside that comp then shifts to a different position? can i have it rasterize but not do that?
Ridley Walker
Re: rasterize but keep position
on Nov 23, 2012 at 12:32:28 am
I'm guessing that you mean the Continuously Rasterize/Collapse Transformations switch in the Timeline.
Its the second half of that pair that may cause position to shift when you invoke it.
See: http://help.adobe.com/en_US/aftereffects/cs/using/WS3878526689cb91655866c11...
Cassius Marques
on Nov 23, 2012 at 11:42:39 am
It's actually keeping it's position. You're just seing it through another camera.
If you just want to upscale to avoid jagged edges. Use the scale composition script and reduce that composition's scale accordinly in your main comp.
Dave LaRonde
on Nov 23, 2012 at 3:06:44 pm
This happens when you build a comp using 3D layers, then you nest it inside another comp and turn on the switch. It becomes a 3D object with its anchor point centered horizontally & vertically and z at zero.
Dave LaRonde
Former Sr. Promotion Producer
