Copying and pasting from Premiere to After Effects WITHOUT making precomps
pawl fisher
on Nov 22, 2012 at 5:20:46 pm
Hey guys,
So on my other workstation I had a good system going where I would copy and paste my edits from Premiere into AE and do all my final compositing.
When I would paste into AE, it would just paste the video files and I would Video Copilot's Trim Compose to make them precomps.
I am on a new workstation on a Mac using cineform MOV and now when I paste from Premiere into AE (on multiple versions) it automatically makes the clips precomps.
This is a problem because I have to go into each precomp to make modifications. Example, in my composition if I want to make a precomp 3d, I have to double click and go inside the precomp and switch it on there! very annoying please please help!!
Dave LaRonde
Re: Copying and pasting from Premiere to After Effects WITHOUT making precomps
on Nov 23, 2012 at 3:08:44 pm
You need to start using Dynamic Link between Premiere Pro and AE. I'm pretty sure your cut 'n paste days are over.
Dave LaRonde
Former Sr. Promotion Producer
pawl fisher
on Nov 26, 2012 at 5:23:10 pm
Uhm so I just tried using Dynamic Link and it did the exact same thing.
It loads the clips as precomps and when I check the 3d box and try to rotate the clip it rotates a frame but the image stays the same.
Import Premiere sequence does the same.
How do I turn off "auto precomping"
dogus aslan
on Feb 9, 2013 at 1:22:21 pm
i would very much like to know the answer to this also.
dogus aslan
on Feb 9, 2013 at 1:36:37 pm
surprised to find the answer, heres the link:
http://forums.adobe.com/thread/645770
just turn off "default scale to framesize" in premiere preferences.this way video will be sent to after effects without pre-composing.
