Render setting for long footage? (from .MTS)
Nekora Snorba
on Nov 21, 2012 at 12:02:09 pm
This time I have been given few 30min long .MTS(Lumix GH2) from a conference. I have worked the .MTS files directly in After Effects CS5.
The final product are videos from 90 to 120min. The problem is that rendering in QT - H.264 I get massive sizes. Although I played around with the render settings seems I do not get any further.
Anyone can suggest some setting that offer nice quality and reasonable size?
Thanks a lot!!
Nekora Snorba
Re: Render setting for long footage? (from .MTS)
on Nov 21, 2012 at 12:56:49 pm
Forgot to say that the footage is 1280 × 720
Walter Soyka
on Nov 21, 2012 at 1:48:50 pm
[Nekora Snorba] "The problem is that rendering in QT - H.264 I get massive sizes. Although I played around with the render settings seems I do not get any further."
You should be able to alter the file size by adjusting the bit rate. Try rendering to MPEG-4 H.264 instead of QuickTime.
[Nekora Snorba] "Anyone can suggest some setting that offer nice quality and reasonable size? "
I guess it depends on your definition of "reasonable" but I'd recommend rendering to an intermediate codec like Apple's ProRes (Mac only), Avid's DNxHD (cross-platform), or Go Pro's CineForm (cross-platform). With a high-quality intermediate like this, you can easily target multiple deliverables.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Nekora Snorba
on Nov 21, 2012 at 7:33:25 pm
Thanks for your answer.
I agree with your idea of rendering to some lossless codec. And then play from there depending on the target.
However I was not planning to keep a copy of this footage. Just render it and give it back to the owners.
Thus, I guess that a ProRes(I am a Mac user) file would be too big for them, as they want to upload the video to the internet.
So, I should keep the same resolution with 'reasonable' quality and size.
I have tried H.264 as you said. Target bitrate 8MBps, Max bitrate 12Mbps.
Quality is good, but is gives me around 1M per second.
Is that normal for this resolution? (1280 × 720)
Does it have anything to do with the .MTS file? It is already compressed. So, in order to get nice quality should I precess it to some lossless format, edit and then render-compress?
Sorry for all this questions. I am a bit lost. Thanks!!!
