Camera Stabalizing & Match Moving
Josh Brine
on Nov 20, 2012 at 8:58:29 pm
I have some test hand held footage i shot, its a bit jerky,
shot on a 5d at a higher shutter speed to see if it helps with tracking.
anyway, i have a question,
if i took this footage into AE, stabalised it, and then exported the stabalised version into my match mover (blender) would it be better? is this a workflow used?
or should i get it near finished then stabalize?
just looking for some pointers on workflow.
thanks
Josh
Roland R. Kahlenberg
Re: Camera Stabalizing & Match Moving
on Nov 21, 2012 at 1:57:16 am
Your biggest worry would be with any rolling shutter artefact. Remove that if it exists (hopefully you shot a grid pattern to guide you).
Once that is done, it doesn't really matter if you stabilize or matchmove first. In fact I would rather matchmove first since stabilization may introduce slight warping which will preclude any decent matchmove solve.
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7)
Josh Brine
on Nov 21, 2012 at 4:57:23 pm
I actually dont have a grid, still working out the ins and outs of shooting this stuff.
I have seen a grid used for correcting/matching lens distortion, is this the same grid? and is it specific?
on Nov 22, 2012 at 2:36:13 am
[Josh Brine] "I have seen a grid used for correcting/matching lens distortion, is this the same grid?"
YUP!
[Josh Brine] "is it specific?"
I don't understand what you mean by "specific". You should be able to create one from a spreadsheet. Print it out and then paste it onto a board.
BTW, mochaAE/Pro 3.1 has a new AE plugin that caters to lens distortion issues. More info here.
HTH
RoRK
