Shatter Doesn't Reflect Source Layer Changes
Cole Christine
on Nov 16, 2012 at 7:08:37 am
I've animated a Shape layer and want it to look 3D by using the Shatter 3D text trick, but for some reason Shatter doesn't show the Shape layer animations; it only shows the first frame of the composition.
The same is true for animated text; Shatter won't display the changes between keyframes that I make to the source text (i.e. words spelling themselves out). Is there a way I can change this?
Roland R. Kahlenberg
Re: Shatter Doesn't Reflect Source Layer Changes
on Nov 16, 2012 at 8:55:01 am
[Cole Christine] "Shatter doesn't show the Shape layer animations; it only shows the first frame of the composition."
This is a limitation of the Shatter effect. Shatter only invokes the first frame of the Custom Shatter Map's shape characteristics .
HTH
RoRK
Intensive mocha & AE Training in Singapore and Other Dangerous Locations
Imagineer Systems (mocha) Certified Instructor
& Adobe After Effects ACE/ACI (version 7)
