text edges jumping
anders bundgaard
text edges jumping
on Nov 13, 2012 at 2:51:19 pm
hi all,
i've got some red text on a white background with a slow creep forward. when viewing the final render the edges seem to jump. my guess is that the size difference from frame to frame is very little and it jumps from one pixel to the next... and red on white doesn't help either i think
is there a way to minimise this?
thanks in advance
John Cuevas
Re: text edges jumping
on Nov 13, 2012 at 3:08:01 pm
You can try to add a de-interlace blur to your text.
Johnny Cuevas, Editor
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Tudor "Ted" Jelescu
on Nov 13, 2012 at 3:10:05 pm
Tweak the red color - de-saturate and also add a .3-.5 blur on the text. This usually helps.
Also this tutorial may help you:
Tudor "Ted" Jelescu
Senior VFX Artist
© 2018 All Rights Reserved
