Jumpy render from Video Copilot Element3D
Morgan Mendieta
on Nov 7, 2012 at 7:08:30 pm
Hello everyone.
I have encountered a problem I have not yet seen and can't seem to put my finger on what is going on.
I have been using Elemen3D and was having problem with mu export I noticed frame ghosting.
A frame from another part of my sequence, and frames that do not exist.
I thought it was the plugin... wrote to videocopilot they game me an update software but nothing.
It does not happen all the time but more often then not.
OSX 10.8 last update.
After Effects updated to last one
16GB RAM
SSD Drive
Macbook Pro 2.6 Ghz
Thanks for any advice.
Kevin Camp
Re: Jumpy render from Video Copilot Element3D
on Nov 7, 2012 at 7:30:38 pm
try choosing edit>purge>all when you see this issue and see if that helps... it sounds like there are cached frames from a previous render are making their way into the current render, and purging the caches may help.
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Morgan Mendieta
on Nov 7, 2012 at 8:05:37 pm
Its strange though because some of the ghost frames that come up are nothing on of my work. Ill try and uplaod a video sample for reference.
Ill give this purge a try never knew it was there.
http://youtu.be/VXeQfBXwOCU
not sure how to add youtube link
Tom Daigon
on Nov 7, 2012 at 9:45:29 pm
Try turning off Mult Processor mode and clearing all caches.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid
Kevin Camp
on Nov 7, 2012 at 10:16:40 pm
it looks a bit like what happens when your video card over heats... element will stress your gpu, so that may be what's happening.
with a macbook, i t wouldn't be easy to open it up and blow it out with some compressed air to make sure the fans are all working well, but you may be able to use a utility like menu meters or istat to monitor the temperature of the gpu (you'd need to heck to see if they monitor the macbook's gpu, or the bay/zone that the gpu is located).
there's also a utility called smcFanControl that may be able to ramp up the fans on the macbook to keep it running cooler (i use it on an older mac pro).
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW
Morgan Mendieta
on Nov 8, 2012 at 5:55:05 am
Thank you all for your input.
Turning off MultiProcessing "Render Multiple Frames Simultaneously" Fixed my problem. tested out 3 times after restart both computer and software and it worked all times.
Thank you this was getting a bit annoying.
Tom Daigon
on Nov 8, 2012 at 2:17:13 pm
Great. Im glad turning off MP resolved your problem.
Tom Daigon
HP Z820 Dual 2687
64GB ram
