Issue with 3D object animated along a motion path
Kieren Smith
on Nov 7, 2012 at 12:53:10 am
Hi Guys,
I've been having this issue for a long while now and I haven't been able to figure out how to fix it.
It involves a 3d object oriented along a motion path... As seen in the video below, the object flips when it passes a keyframe I'm only keyframing the position not the rotation but it seems EVERYTIME I create this kind of an effect it does this... Any ideas of how to fix this flip?.. Also when ever you stop on a keyframe, the object is rotated some how and is barely visible...
Here is the Video:
http://reels.creativecow.net/film/3d-orient-to-path-motion-path-test
Here is the Project file for the video so you can see my setup:
4923_3dmotionpathtest.aep.zip
