AE CS6 crashes.....
Dave Hirschberg
AE CS6 crashes.....
on Nov 5, 2012 at 7:32:53 pm
I know this is very vague but I'm not sure how much more detail I can give....
I was working on a project for a few days with no issues at all. Today I turned on motion blur for all the layers and AE crashed. Now I can't open the project or any of the auto saves! Other projects open just fine. The plugins being used were Invig Pro 6.0.0, Generate-Fill and the scribble effect. I'm on a 2008ish Mac Pro with 10.6.8. Here is the crash log in case anyone can read it...
Process: After Effects [66238]
Path: /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/After Effects
Identifier: com.adobe.AfterEffects
Version: 11.0.2 (11.0)
Code Type: X86-64 (Native)
Parent Process: launchd [147]
Date/Time: 2012-11-05 14:31:49.728 -0500
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 427050 sec
Crashes Since Last Report: 24
Per-App Interval Since Last Report: 419964 sec
Per-App Crashes Since Last Report: 17
Anonymous UUID: 4C9B68FD-BB0C-48AB-8A89-251BFF47BB5B
Exception Type: EXC_BAD_ACCESS (SIGABRT)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000002
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Application Specific Information:
abort() called
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x00007fff87d540b6 __kill + 10
1 libSystem.B.dylib 0x00007fff87df49f6 abort + 83
2 U.dylib 0x0000000102b78f42 U_LoadFrameworkBundle + 562
3 com.adobe.dvacore.framework 0x0000000102fcb535 (anonymous namespace)::SignalHandler(int, __siginfo*, void*) + 261
4 libSystem.B.dylib 0x00007fff87d661ba _sigtramp + 26
5 ??? 0x00007fff5fbf91a0 0 + 140734799778208
6 com.adobe.psl 0x000000010c63edfd PSSLO::ConstAutoResource::ConstAutoResource() + 3532573
7 com.adobe.psl 0x000000010c63f0da PSSLO::ConstAutoResource::ConstAutoResource() + 3533306
8 com.adobe.psl 0x000000010c63f1d3 PSSLO::ConstAutoResource::ConstAutoResource() + 3533555
9 com.adobe.psl 0x000000010c6383ca PSSLO::ConstAutoResource::ConstAutoResource() + 3505386
10 com.adobe.psl 0x000000010ca8450e PSLSetImageGuides + 1435470
11 com.adobe.psl 0x000000010c91dc6b PSLCreateStringUTF8 + 464203
12 com.adobe.psl 0x000000010c91cce9 PSLCreateStringUTF8 + 460233
13 com.adobe.psl 0x000000010c89940f PSLGetPreferences + 11343
14 com.adobe.psl 0x000000010c8998f4 PSLShutdown + 388
15 COR.dylib 0x000000010168bf91 COR_InitPSL() + 145
16 PIN.dylib 0x0000000101d292bc PIN_GetLive3D(PIN_SeqSpec**) + 5004
17 PIN.dylib 0x0000000101d29bb3 D_PS3p_NewOptionsInfo + 323
18 PIN.dylib 0x0000000101cbf4bf PIN_ConvertOutputInfoFromDiskV1 + 1087
19 PIN.dylib 0x0000000101cc220e PIN_ReadSeqSpec + 894
20 BEE.dylib 0x00000001010ea75b BEE_Layer::ReadPlus(SLU_File*, SLU_ChunkInfo const*, BEEp_FileInfo*, BEE_LayerData const&, std::basic_string const*, BEE_Project*) + 3161
21 BEE.dylib 0x00000001010ec733 BEE_Layer::ReadPlus(SLU_File*, SLU_ChunkInfo const*, BEEp_FileInfo*, BEE_LayerData const&, std::basic_string const*, BEE_Project*) + 11313
22 BEE.dylib 0x00000001010f1529 BEE_SaveProject(BEE_Project*, unsigned int, unsigned int, int, int, int, int, BEE_ActiveItemInfo const*, std::set const*, FILE_Spec*) + 14921
23 BEE.dylib 0x00000001010f1f81 BEE_LoadProject(FILE_Spec*, BEE_FolderItem*, unsigned char, unsigned char, unsigned char*, BEE_ActiveItemInfo*, unsigned int*, BEE_Project*) + 193
24 BEE.dylib 0x000000010100c9eb BEE_TimeDisplayFormat2T_TimeFormatInfo(BEE_TimeDisplayFormat const*, T_TimeFormatInfo*) + 491
25 BEE.dylib 0x00000001011a097e BEE_UndoRedoCount(int*, int*) + 110
26 BEE.dylib 0x000000010100eb31 BEE_DoCommand(short, BEE_CommandInfo*) + 449
27 ...e.AfterEffectsLib.framework 0x00000001007f5f7b CPDir::SaveProjectToFileSpec(FILE_Spec*, int, bool) + 5515
28 ...e.AfterEffectsLib.framework 0x000000010042a48a CEggApp::OpenDocument(FILE_Spec**, unsigned char, unsigned char, unsigned char) + 404
29 ...e.AfterEffectsLib.framework 0x00000001004bd5c7 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 127543
30 ...e.AfterEffectsLib.framework 0x000000010042273f CEggApp::DoCommand(int) + 6333
31 ...e.AfterEffectsLib.framework 0x00000001004f9014 dvacore::utility::SearchLiveHelp(std::basic_string) + 12612
32 ...e.AfterEffectsLib.framework 0x00000001004f9014 dvacore::utility::SearchLiveHelp(std::basic_string) + 12612
33 ...e.AfterEffectsLib.framework 0x00000001007c0540 WF_WatchFolder(FILE_Spec*) + 129472
34 ...e.AfterEffectsLib.framework 0x00000001004d1d9f CSwitchboard::DoCommandHilite(int) + 113
35 ...e.AfterEffectsLib.framework 0x000000010042b1d6 CEggApp::DoKeyboardEvent(dvaui::ui::KeyboardEvent const&) + 472
36 ...e.AfterEffectsLib.framework 0x00000001004f7ddd dvacore::utility::SearchLiveHelp(std::basic_string) + 7949
37 ...e.AfterEffectsLib.framework 0x00000001004f7afd dvacore::utility::SearchLiveHelp(std::basic_string) + 7213
38 com.adobe.dvaui.framework 0x00000001034b7c9f dvaui::ui::UI_Node::UI_DispatchKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 505
39 com.adobe.dvaui.framework 0x00000001035072e9 dvaui::ui::OS_Node::UI_DispatchKeyboardEventFromOS(dvaui::ui::OS_Event*) + 155
40 com.adobe.dvaui.framework 0x000000010351acad dvaui::ui::OS_Window::UI_DispatchEvent(dvaui::ui::OS_Event*) + 79
41 com.adobe.dvaui.framework 0x0000000103523849 boost::detail::function::function_obj_invoker0::invoke(boost::detail::function::function_buffer&) + 41
42 FLT.dylib 0x0000000101791845 int dvacore::config::ErrorManager::ExecuteFunction(boost::function0*, bool*) + 31
43 ...e.AfterEffectsLib.framework 0x000000010045cf6e EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 1918
44 FLT.dylib 0x000000010179172e bool dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0, bool*) + 112
45 FLT.dylib 0x0000000101794e1d bool dvacore::config::ExecuteTopLevelFunction(boost::function0, bool*) + 125
46 com.adobe.dvaui.framework 0x00000001035167b4 -[DVAMacPanelWindow performKeyEquivalent:] + 212
47 com.apple.AppKit 0x00007fff83c2aa9b -[NSApplication _handleKeyEquivalent:] + 221
48 com.apple.AppKit 0x00007fff83afb6b9 -[NSApplication sendEvent:] + 3630
49 com.adobe.dvaui.framework 0x000000010350e0c6 -[DVAMacApplication sendEvent:] + 630
50 ...e.AfterEffectsLib.framework 0x00000001002d37d7 0x1002a1000 + 206807
51 com.apple.AppKit 0x00007fff83a926de -[NSApplication run] + 474
52 ...e.AfterEffectsLib.framework 0x00000001004bd955 PT_RegisterTracker(A_Version, A_Version, int, _AEGP_GlobalRefcon*, char const*, char const*, PT_TrackerEntryPoints const*) + 128453
53 ...e.AfterEffectsLib.framework 0x000000010045c06b SetAPETerminateFunc(boost::function const&) + 891
54 ...e.AfterEffectsLib.framework 0x000000010045c82d EggMain(bool, bool, bool, bool, bool, bool, char*, bool, int) + 61
55 com.adobe.AfterEffects 0x0000000100003aad main + 1677
56 com.adobe.AfterEffects 0x000000010000340c start + 52
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x00007fff87d1ec0a kevent + 10
1 libSystem.B.dylib 0x00007fff87d20add _dispatch_mgr_invoke + 154
2 libSystem.B.dylib 0x00007fff87d207b4 _dispatch_queue_invoke + 185
3 libSystem.B.dylib 0x00007fff87d202de _dispatch_worker_thread2 + 252
4 libSystem.B.dylib 0x00007fff87d1fc08 _pthread_wqthread + 353
5 libSystem.B.dylib 0x00007fff87d1faa5 start_wqthread + 13
Thread 2:
0 libSystem.B.dylib 0x00007fff87d40a6a __semwait_signal + 10
1 libSystem.B.dylib 0x00007fff87d44881 _pthread_cond_wait + 1286
2 ...ple.CoreServices.CarbonCore 0x00007fff8249cd87 TSWaitOnCondition + 118
3 ...ple.CoreServices.CarbonCore 0x00007fff8240bff8 TSWaitOnConditionTimedRelative + 177
4 ...ple.CoreServices.CarbonCore 0x00007fff82405efb MPWaitOnQueue + 215
5 com.adobe.dvacore.framework 0x0000000102f45ce4 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr&, int) + 200
6 com.adobe.dvacore.framework 0x0000000102f42fe3 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 115
7 com.adobe.dvacore.framework 0x0000000102f406d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 163
8 ...obe.boost_threads.framework 0x000000010ab2face thread_proxy + 158
9 libSystem.B.dylib 0x00007fff87d3efd6 _pthread_start + 331
10 libSystem.B.dylib 0x00007fff87d3ee89 thread_start + 13
Thread 3:
0 libSystem.B.dylib 0x00007fff87d05dda semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x00007fff87d44772 _pthread_cond_wait + 1015
2 ...ple.CoreServices.CarbonCore 0x00007fff8240c018 TSWaitOnConditionTimedRelative + 209
3 ...ple.CoreServices.CarbonCore 0x00007fff82405efb MPWaitOnQueue + 215
4 com.adobe.dvacore.framework 0x0000000102f45ce4 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::auto_ptr&, int) + 200
5 com.adobe.dvacore.framework 0x0000000102f42fe3 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 115
6 com.adobe.dvacore.framework 0x0000000102f406d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 163
7 ...obe.boost_threads.framework 0x000000010ab2face thread_proxy + 158
8 libSystem.B.dylib 0x00007fff87d3efd6 _pthread_start + 331
9 libSystem.B.dylib 0x00007fff87d3ee89 thread_start + 13
Thread 4:
0 libSystem.B.dylib 0x00007fff87d41aae getattrlist + 10
1 ...ple.CoreServices.CarbonCore 0x00007fff823e7359 getattrlist_retry(unsigned int, unsigned int, char const*, unsigned int, attrlist*, void*, unsigned int, unsigned int) + 160
2 ...ple.CoreServices.CarbonCore 0x00007fff823e6bee GetVolFSAttributes(FSMount*, unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned int, FSVolAttributeInfo*, unsigned char*) + 766
3 ...ple.CoreServices.CarbonCore 0x00007fff823e6886 FSMount::_getattrs(unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 296
4 ...ple.CoreServices.CarbonCore 0x00007fff823e6716 FSMount::getattrs(unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 248
5 ...ple.CoreServices.CarbonCore 0x00007fff823e65f1 GetFSRefAttributes(FSMount*, FSRefPrivate const*, unsigned int, FSAttributeInfo*, unsigned int, char*) + 193
6 ...ple.CoreServices.CarbonCore 0x00007fff823e6335 PBGetCatalogInfoSync + 250
7 ...ple.CoreServices.CarbonCore 0x00007fff823e6238 FSGetCatalogInfo + 40
8 com.adobe.dvacore.framework 0x0000000102ead9c9 dvacore::filesupport::FileHelper::Exists() const + 111
9 com.adobe.dvacore.framework 0x0000000102f080d1 dvacore::filesupport::FileHelper::Created() const + 25
10 MC.dylib 0x0000000101866f03 MC_SortDir::ScanDiskCacheDir() + 425
11 com.adobe.dvacore.framework 0x0000000102f336ea dvacore::threads::(anonymous namespace)::SubExecutorImpl::CallFunctionWithExceptionHandler(boost::function const&) + 52
12 com.adobe.dvacore.framework 0x0000000102f3330b dvacore::threads::(anonymous namespace)::SubExecutorImpl::ExecuteDelayedFunction(boost::weak_ptr const&, int) + 523
13 com.adobe.dvacore.framework 0x0000000102f43032 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, boost::shared_ptr const&) + 194
14 com.adobe.dvacore.framework 0x0000000102f406d3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0 const&, dvacore::threads::ThreadPriority, boost::function const&, boost::function const&) + 163
15 ...obe.boost_threads.framework 0x000000010ab2face thread_proxy + 158
16 libSystem.B.dylib 0x00007fff87d3efd6 _pthread_start + 331
17 libSystem.B.dylib 0x00007fff87d3ee89 thread_start + 13
Thread 5:
Thread 6:
5 com.adobe.ACE 0x000000010babf2c9 0x10ba86000 + 234185
6 com.adobe.ACE 0x000000010babe5da 0x10ba86000 + 230874
7 ...ple.CoreServices.CarbonCore 0x00007fff823de0d1 PrivateMPEntryPoint + 63
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:
Thread 12:
Thread 13:
5 ...obe.ASLFoundation.framework 0x0000000105c03320 ASL::(anonymous namespace)::TaskProc(void*) + 160
6 ...ple.CoreServices.CarbonCore 0x00007fff823de0d1 PrivateMPEntryPoint + 63
7 libSystem.B.dylib 0x00007fff87d3efd6 _pthread_start + 331
8 libSystem.B.dylib 0x00007fff87d3ee89 thread_start + 13
Thread 14:
Thread 15:
Thread 16:
Thread 17:
1 ...dobe.dvatransport.framework 0x0000000108e23f12 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue&) + 240
2 ...dobe.dvatransport.framework 0x0000000108e2e0da boost::asio::detail::task_io_service::do_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service::idle_thread_info*) + 512
3 ...dobe.dvatransport.framework 0x0000000108e2e467 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 291
4 ...dobe.dvatransport.framework 0x0000000108e1afbd SkyConnectionEnv::MainLoop() + 129
5 ...dobe.dvatransport.framework 0x0000000108e1b03b SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
6 ...obe.boost_threads.framework 0x000000010ab2face thread_proxy + 158
Thread 18:
2 ...dobe.dvatransport.framework 0x0000000108e2e04b boost::asio::detail::task_io_service::do_one(boost::asio::detail::scoped_lock&, boost::asio::detail::task_io_service::idle_thread_info*) + 369
4 ...dobe.dvatransport.framework 0x0000000108e1bc2a boost::asio::detail::posix_thread::func::run() + 42
5 ...dobe.dvatransport.framework 0x0000000108e1ec33 boost_asio_detail_posix_thread_function + 19
Thread 19:
0 libSystem.B.dylib 0x00007fff87d05d7a mach_msg_trap + 10
1 libSystem.B.dylib 0x00007fff87d063ed mach_msg + 59
2 com.apple.CoreFoundation 0x000000010915e902 __CFRunLoopRun + 1698
3 com.apple.CoreFoundation 0x000000010915dd8f CFRunLoopRunSpecific + 575
4 com.apple.audio.CoreAudio 0x00007fff87029786 HALRunLoop::OwnThread(void*) + 152
5 com.apple.audio.CoreAudio 0x00007fff87016755 CAPThread::Entry(CAPThread*) + 125
Thread 20:
2 com.adobe.AfterEffects.MThread 0x000000013fa53017 main + 27303
3 com.adobe.AfterEffects.MThread 0x000000013fa530ce main + 27486
Thread 21:
Thread 22:
Thread 23:
Thread 24:
Thread 25:
Thread 26:
Thread 27:
Thread 28:
2 com.adobe.AfterEffects.OpenEXR 0x0000000142713484 IlmThread::Semaphore::wait() + 100
3 com.adobe.AfterEffects.OpenEXR 0x0000000142712546 IlmThread::(anonymous namespace)::WorkerThread::run() + 182
4 libSystem.B.dylib 0x00007fff87d3efd6 _pthread_start + 331
5 libSystem.B.dylib 0x00007fff87d3ee89 thread_start + 13
Thread 29:
Thread 30:
Thread 31:
Thread 32:
Thread 33:
Thread 34:
Thread 35:
Thread 36:
1 libSystem.B.dylib 0x00007fff87d408f9 nanosleep + 148
2 ...dobe.AfterEffects.Scripting 0x000000014398b3eb zcalloc + 188043
3 ...dobe.AfterEffects.Scripting 0x0000000143972069 zcalloc + 84745
4 ...dobe.AfterEffects.Scripting 0x000000014398b736 zcalloc + 188886
5 libSystem.B.dylib 0x00007fff87d3efd6 _pthread_start + 331
6 libSystem.B.dylib 0x00007fff87d3ee89 thread_start + 13
Thread 37:
2 com.adobe.ape.engine 0x00000001444ecc0d APXGetHostAPI + 2516093
3 com.adobe.ape.engine 0x000000014429aec1 APXGetHostAPI + 83761
4 com.adobe.ape.engine 0x00000001444eccd1 APXGetHostAPI + 2516289
5 com.adobe.ape.engine 0x00000001444ecd4a APXGetHostAPI + 2516410
6 com.adobe.ape.engine 0x00000001444ece79 APXGetHostAPI + 2516713
Thread 38:
Thread 39:
Thread 40:
Thread 41:
Thread 42:
Thread 43:
Thread 44:
Thread 45:
4 com.apple.CoreMediaIOServices 0x00007fff8725c5f7 MIO::DAL::RunLoop::OwnThread(void*) + 147
5 com.apple.CoreMediaIOServices 0x00007fff8725e1c2 CAPThread::Entry(CAPThread*) + 140
Thread 46:
2 com.adobe.ape.engine 0x00000001444ecbd0 APXGetHostAPI + 2516032
3 com.adobe.ape.engine 0x0000000144504ddb APXGetHostAPI + 2614859
Thread 47:
3 com.adobe.ape.engine 0x000000014467f2c3 APXGetHostAPI + 4164403
Thread 48:
2 libtbb.dylib 0x0000000100017010 tbb::internal::rml::private_worker::thread_routine(void*) + 416
3 libSystem.B.dylib 0x00007fff87d3efd6 _pthread_start + 331
4 libSystem.B.dylib 0x00007fff87d3ee89 thread_start + 13
Thread 49:
Thread 50:
Thread 51:
Thread 52:
Thread 53:
Thread 54:
Thread 55: com.apple.CFSocket.private
0 libSystem.B.dylib 0x00007fff87d49932 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x0000000109180468 __CFSocketManager + 824
2 libSystem.B.dylib 0x00007fff87d3efd6 _pthread_start + 331
3 libSystem.B.dylib 0x00007fff87d3ee89 thread_start + 13
Thread 56:
Thread 57:
2 com.zaxwerks.AE.3DInvigorator 0x000000015709391b gomp_sem_wait + 75
3 com.zaxwerks.AE.3DInvigorator 0x00000001570939cf gomp_barrier_wait_end + 143
4 com.zaxwerks.AE.3DInvigorator 0x000000015709308d gomp_thread_start + 333
Thread 58:
Thread 59:
Thread 60:
Thread 61:
Thread 62:
Thread 63:
Thread 64:
2 com.apple.audio.CoreAudio 0x00007fff8701668c CAGuard::WaitFor(unsigned long long) + 168
3 com.apple.audio.CoreAudio 0x00007fff87018c1b CAGuard::WaitUntil(unsigned long long) + 185
4 com.apple.audio.CoreAudio 0x00007fff87016d85 HP_IOThread::WorkLoop() + 1369
5 com.apple.audio.CoreAudio 0x00007fff87016827 HP_IOThread::ThreadEntry(HP_IOThread*) + 9
6 com.apple.audio.CoreAudio 0x00007fff87016755 CAPThread::Entry(CAPThread*) + 125
Thread 65:
0 libSystem.B.dylib 0x00007fff87d1fa2a __workq_kernreturn + 10
1 libSystem.B.dylib 0x00007fff87d1fe3c _pthread_wqthread + 917
2 libSystem.B.dylib 0x00007fff87d1faa5 start_wqthread + 13
Thread 66:
Thread 67:
4 com.apple.CoreFoundation 0x000000010915db16 CFRunLoopRun + 70
5 com.apple.DesktopServices 0x00007fff8689f326 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 514
Thread 68:
Thread 69: Dispatch queue: TFSVolumeInfo::GetSyncGCDQueue
1 ...ple.CoreServices.CarbonCore 0x00007fff823fbaa5 FSMount::getattrscore(bool, char const*, unsigned int, char const*, unsigned int, FSAttributeInfo*, unsigned int, unsigned char*) + 835
2 ...ple.CoreServices.CarbonCore 0x00007fff823fac28 FSMount::getattrsbulk(void*, unsigned int, unsigned long*, unsigned int, unsigned int, FSAttributeInfo*, unsigned char*, unsigned char*) + 842
3 ...ple.CoreServices.CarbonCore 0x00007fff823fa619 PBGetCatalogInfoBulkSync + 589
4 ...ple.CoreServices.CarbonCore 0x00007fff823fa3aa FSGetCatalogInfoBulk + 66
5 com.apple.DesktopServices 0x00007fff868c044b TFSIterator::NextSingle(TCountedPtr&) + 209
6 com.apple.DesktopServices 0x00007fff868bfeb5 TFSInfoSynchronizer::FetchChildren() + 165
7 com.apple.DesktopServices 0x00007fff868a979b TNode::SynchronizeChildren(unsigned int, TNodeEventPtrSet&) + 241
8 com.apple.DesktopServices 0x00007fff868a9242 TNode::HandleSync(unsigned int) + 736
9 com.apple.DesktopServices 0x00007fff868a8f33 TNode::HandleSync(TCountedPtr const&, TNodePtr const&) + 45
10 com.apple.DesktopServices 0x00007fff868e7964 TNode::HandleNodeRequest(TCountedPtr const&, TCountedPtr const&) + 1052
11 com.apple.DesktopServices 0x00007fff868a74a8 __PostNodeTaskRequest_block_invoke_2 + 98
12 libSystem.B.dylib 0x00007fff87d41d64 _dispatch_call_block_and_release + 15
13 libSystem.B.dylib 0x00007fff87d208d2 _dispatch_queue_drain + 251
14 libSystem.B.dylib 0x00007fff87d20734 _dispatch_queue_invoke + 57
15 libSystem.B.dylib 0x00007fff87d202de _dispatch_worker_thread2 + 252
16 libSystem.B.dylib 0x00007fff87d1fc08 _pthread_wqthread + 353
17 libSystem.B.dylib 0x00007fff87d1faa5 start_wqthread + 13
Thread 70:
Thread 71:
3 ...ple.CoreServices.CarbonCore 0x00007fff8240bdc6 TSWaitOnSemaphoreCommon + 416
4 ...ple.CoreServices.CarbonCore 0x00007fff8240bac4 AsyncFileThread(void*) + 61
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x00007fff5fbf89c0 rcx: 0x00007fff5fbf8978 rdx: 0x0000000000000000
rdi: 0x00000000000102be rsi: 0x0000000000000006 rbp: 0x00007fff5fbf8990 rsp: 0x00007fff5fbf8978
r8: 0x00007fff5fbf8938 r9: 0x000000014c3b8510 r10: 0x00007fff87d500fa r11: 0x0000000000000202
r12: 0x0000000102b78ea0 r13: 0x0000000000000000 r14: 0x00007fff5fbf89b0 r15: 0x000000000000000b
rip: 0x00007fff87d540b6 rfl: 0x0000000000000202 cr2: 0x000000011480b49a
Binary Images:
0x100000000 - 0x100003fff +com.adobe.AfterEffects 11.0.2 (11.0) /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/MacOS/After Effects
0x100008000 - 0x100034ff7 +libtbb.dylib ??? (???) <57655978-A378-BE1E-7905-7D7F951AD6F7> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libtbb.dylib
0x10004b000 - 0x100059ff3 +libtbbmalloc.dylib ??? (???) /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/libtbbmalloc.dylib
0x10006d000 - 0x100079fff +com.adobe.boost_signals.framework 6.0.0 (6.0.0.339847) <37FE0EE8-CE3B-499D-881C-7F6400B8384A> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
0x100091000 - 0x100094fff +com.adobe.boost_system.framework 6.0.0 (6.0.0.339847) <18F38BB7-5529-1655-2E49-EDADB686460E> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
0x10009a000 - 0x1000a1fff +com.adobe.boost_date_time.framework 6.0.0 (6.0.0.339847) <0065F9F7-91BA-E8F4-3DAB-52D7A157A850> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
0x1000bc000 - 0x1001b8ff7 +hydra_filters ??? (???) <4605CB0B-62A0-5BAB-D593-7DFB63F6042B> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/hydra_filters.framework/Versions/A/hydra_filters
0x100257000 - 0x100271fff +image_runtime ??? (???) /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
0x10029d000 - 0x10029eff7 +ALOG.dylib ??? (???) <1442F648-F885-64DF-C453-35232AC8EF19> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/ALOG.dylib
0x1002a1000 - 0x100d13fff +com.adobe.AfterEffectsLib.framework AfterFXLib 1.0 (1.0) <8A4A9D50-B020-D947-13F8-D79E2DF86057> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AfterFXLib.framework/Versions/A/AfterFXLib
0x100f70000 - 0x100f70fff +AEFX.dylib ??? (???) <8097A384-C863-85D8-D422-5C17BD185AFD> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/AEFX.dylib
0x100f73000 - 0x101451ff7 +BEE.dylib ??? (???) <0FB2C7AA-9BCD-C9F4-1B60-A6D3A2956C59> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BEE.dylib
0x10164f000 - 0x10165dfef +BEZ.dylib ??? (???) <2CD80E9F-966D-FE0B-8322-3EBC2190FEAF> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BEZ.dylib
0x101662000 - 0x10166cff7 +BM.dylib ??? (???) /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/BM.dylib
0x101674000 - 0x1016c1fff +COR.dylib ??? (???) <37F2DA01-28C8-3C73-2AED-D26FDC255A0B> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/COR.dylib
0x1016e4000 - 0x101705fff +FILE.dylib ??? (???) /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FILE.dylib
0x101715000 - 0x10173ffff +FLO.dylib ??? (???) <4122DB96-6BE7-8991-C33F-959B1809EBA8> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FLO.dylib
0x101744000 - 0x1017d8fff +FLT.dylib ??? (???) <4EDA3A1B-F3EC-1CA2-39F6-B27FF54697CF> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/FLT.dylib
0x101836000 - 0x10183cff7 +LIST.dylib ??? (???) <63408BFE-7A9C-9A43-7471-556E8981FF96> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/LIST.dylib
0x101840000 - 0x10185aff7 +M.dylib ??? (???) <9A87636F-A4D1-BD25-8EAD-CDBAF9AC49C4> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/M.dylib
0x101862000 - 0x101883fff +MC.dylib ??? (???) <2F043BC4-C0E5-1815-3E20-8A77548B938E> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MC.dylib
0x101895000 - 0x1018f4fff +MSK.dylib ??? (???) <447FFF12-D5C7-EB97-7E67-0FF583584FBD> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/MSK.dylib
0x101907000 - 0x101951ff7 +OM.dylib ??? (???) <1B933233-25FD-CFC9-95F2-B6561032834E> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/OM.dylib
0x101968000 - 0x10198cfef +P.dylib ??? (???) /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/P.dylib
0x101995000 - 0x101c54ff7 +PF.dylib ??? (???) <247A78C0-A969-B67E-31FB-24A2F5F785BF> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks/PF.dylib
0x101c7d000 - 0x101ef1fff +PIN.dylib ??? (???) <5FE76C21-AA8D-1593-CD3C-419B505D2821> /Applications/Adobe CS6/Adobe After Effects CS6/Adobe After Effects CS6.app/Contents/Frameworks
Vishesh Arora
Re: AE CS6 crashes.....
on Nov 5, 2012 at 8:03:10 pm
Dave
There is one way to open the corrupt file in Ae but it works in 50% cases.
Open AE, a new project and then import your corrupt file in that project itself. It may open the corrupt file.
It may work. Also, I would recommend everyone to keep Auto save(AE files wont take much space) on for future projects or you can save manually after regular interval with increment numbers.
Vishesh Arora
3D and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
Demo Reel(3D):
Dave Hirschberg
on Nov 5, 2012 at 8:34:02 pm
Hey Vishesh,
I thought of that as well but I figured I'd restart just to see if that worked and bingo! No idea why but I'm back up again. Thanks for the response though!
Dave Hirschberg
Art Director | WNJU Telemundo/NBC
2200 Fletcher Ave 6th Floor Fort Lee, NJ 07024
Office: 201.969.4204 | Cell: 201.304.1057
david.hirschberg@nbcuni.com
Walter Soyka
on Nov 6, 2012 at 1:29:46 am
Glad you're back up and running.
If something similar happens in the future, I usually recommend opening the project with Caps Lock on to suppress rendering.
I've found some of the GPU-based plugins can be a bit dodgy on the Mac, and sometimes crash immediately upon load. Deferring rendering with Caps Lock on for even a couple seconds seems to avoid that crash sometimes.
Suppressing rendering until after the project is open and you can see where the CTI is can also help you track down the problem.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Dave Hirschberg
on Nov 6, 2012 at 5:15:48 pm
Hey Walter, thanks for the response. I did the caps lock on startup and it still crashed. I still don't know what was causing the crash but for whatever reason, the restart cured it.
Dave
Dave Hirschberg
