Continuously Rasterize Switch Missing in CS4
Ray East
on Oct 31, 2012 at 7:20:48 pm
Hi guys and gals,
I'm trying to import some Illustrator files, but they are all pixelated when I scale them more than 100%. They are also pixelated when I render the final file. The Continuously Rasterize switch is nowhere to be found... Can someone help?
I know that some AI files can actually be rasters, but this is not the case...
Thanks in advance!
Ray
Jeff Hinkle
Re: Continuously Rasterize Switch Missing in CS4
on Oct 31, 2012 at 9:31:42 pm
Hit the "Toggle Switches/Modes" button at the bottom of the timeline window. If that still doesn't do the trick, try right-clicking on the column bar (the strip that has the eyeball/audio/solo/lock icons) in the timeline window, choose the Columns flyout and make sure "Switches" has a checkmark by it.
It is easier to destroy than to create.
More fun, too.
