Is it worth running CS6 on 1st Gen MAc Pro?
Chris Heuer
on Oct 31, 2012 at 2:21:59 pm
Hello. I am trying to decide whether or not to upgrade from CS5 to CS6.
I have an 8 core 1st Generation Mac Pro with an ATI Radeon 1900 Graphics card and 16 gigs of RAM. I can't upgrade to any of the cards that Adobe lists on their support page as "Approved" for CS6's GPU enhancements.
Will CS6 run at a reasonable pace or is the software getting too GPU-centric for older systems (in other words, would it be slower on a system like mine?).
Thanks in advance for any insight!
Chris
Chris Heuer
Freefall FX, LLC
Dave LaRonde
Re: Is it worth running CS6 on 1st Gen MAc Pro?
on Oct 31, 2012 at 2:58:33 pm
Other than the extreme slow speed, you may face a more fundamental problem: your Mac's operating system. AE CS6 may not even run on it. You would have to check that before even considering an installation.
Dave LaRonde
Former Sr. Promotion Producer
Chris Heuer
on Oct 31, 2012 at 3:11:40 pm
Ahhh. I did fail to add, I am running Snow Leopard. I think I can go as far as Lion but from what I understand Mountain Lion is not possible.
C
Chris Heuer
Freefall FX, LLC
Brian Charles
on Oct 31, 2012 at 3:20:34 pm
I'm running CS6 on Snow Leopard, no issues at all. You can download a trial version from Adobe to test performance on your machine.
Chris Heuer
on Oct 31, 2012 at 3:25:57 pm
Good point! I always forget about that. Thanks for the input. I have been getting bummed with my hardware limitations. I hope the Mac Pro update in mid 2013 is significant... and maybe a little early.
Chris
Chris Heuer
Freefall FX, LLC
Walter Soyka
on Oct 31, 2012 at 6:05:44 pm
A 2006 Mac Pro would get smoked by a modern MBP or iMac...
But if you can in fact run CS6, the Global Performance Cache could be a huge performance increase for you. As always, max out the RAM in your system and get a fast SSD for the cache for the best performance.
Walter Soyka
RenderBreak Blog - What I'm thinking when my workstation's thinking
Nevin Styre
on Nov 2, 2012 at 6:59:50 am
Worth trying, you can do the 30 day free trial.
At work I run CS6 on a mac pro 2,1, 10gb ram, with the same video card. I definitely get better render times on my own PC and my macbook pro but a lot of work gets done on the mac pro still, mostly working in 720p and standard def using much of the production suite. I usually do advanced AE comps at home or on my macbook if it is complex and/or needs raytracing or element 3d.
Chris Heuer
on Nov 2, 2012 at 12:07:03 pm
Thanks for that info. Element 3D was one of the other plug-ins I was pretty sure would suffer on this system. I had a little hope the Radeon card would work with it but was pretty sure it wouldn't.
Chris
Chris Heuer
Freefall FX, LLC
