How to make SureTarget do a full 360 Spin
Richard van den Boogaard
on Oct 18, 2012 at 7:42:57 pm
I have set up a scene involving a central object surrounded by four nulls (North-East-South-West) and I use a separate null to which VideoCopilot's Sure Target is applied (and which creates the camera).
When I fly the camera from North to West the motion is the way I want (rotation clockwise). However on the final part of the journey, from West back to North, the camera all of a sudden changes direction and goes back in counter clockwise mode.
Any idea how to make Sure Target do multiple full 360 spins?
Thanks much.
Freelance cameraman • Glidecam Operator • Editor • YouTube expert
Tom Daigon
Re: How to make SureTarget do a full 360 Spin
on Oct 18, 2012 at 9:02:01 pm
You might get a quicker response if you pose this question to Video Copilot tech support.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid
on Oct 20, 2012 at 10:49:14 am
I figured it out. Turns out that I had my camera move in Ae set up wrong. If you start off in the East (e.g. -90 degrees), then go South, West, North, you have to keep adding 90 degrees of rotation in the proper direction, otherwise the camera spins backwards.
Can be mind-boggling none the less when you overlook such simple stuff...
Cheers,
Richard
