How do i copy the anchor point of a layer to somewhere else without moving the layer?
Josh Brine
on Oct 15, 2012 at 6:58:46 pm
im pretty sure there is a method/hotkey to make this happen
i have a graphic layer, and a txt layer below it. i want to scale them both to the centre of the graphic layer instead of manually placing the anchor point to the center of the graphic i want to copy and paste the anchor point data from the graphic to the txt, but it moves the layer in relation to the movement of the AP, how do i prevent this position movement from happening?
Darby Edelen
Re: How do i copy the anchor point of a layer to somewhere else without moving the layer?
on Oct 16, 2012 at 1:16:51 am
In your case you can parent the text layer to the graphic layer and then scale the graphic layer.
Darby Edelen
