Room Edge Bend Effect?
Max Jackson
on Oct 15, 2012 at 7:59:12 am
Hi CC,
I have an effect that travels down the edge of a room.
Is there an effect that can help me distort my comp so it splits and I can adjust the angle to relatively match?
Or....am I just going to have to split this thing in half and eyeball it myself?
Any reference to something that would help me speed this up would be awesome.
Thanks for reading. :)
Tudor "Ted" Jelescu
Re: Room Edge Bend Effect?
on Oct 15, 2012 at 8:36:17 am
It would be easier if you can post a still and be more specific on what kind of effect you are looking to apply. I can think of a way to do this but only for certain kinds of effects. Post some more details.
Tudor "Ted" Jelescu
Senior VFX Artist
Max Jackson
on Oct 15, 2012 at 9:37:33 am
Hi Ted,
Most gladly, picture below. I've got this thing growing out of the corner and I need it to split perspectives growing downward. I can do this by masking the comp in halves and ball-parking perspective, but...this project is going to have me do this probably at least half a dozen times.
Was wondering if there was a plugin or some solution available that can help distort a basic line for this application.
Tudor "Ted" Jelescu
on Oct 15, 2012 at 12:29:09 pm
If you're referring to the shadow branches/roots, I would pre-comp the animation, make it 3d and change the anchor point to have the Y axis at the point where you want the bend to be, duplicate and rotate one of the layers to match perspective. Link one layer to the other and use the latter to position both. This way you have one animation/effect that can be adjusted in the pre-comp and the ability to position and match perspective.
Another way would be to use Free Form or FreeForm Pro to bend a layer in 3d space and match the walls.
Tudor "Ted" Jelescu
Senior VFX Artist
Max Jackson
on Oct 15, 2012 at 6:59:31 pm
Perfect. Thanks Ted!
Max Jackson
on Oct 16, 2012 at 4:15:13 am
Actually, also an added step that would really help as well would be to...
After setting the anchor point like you mentioned use a basic triangle or square primitive to represent angles of the effects shape/object you want to use and then once the angles are flush turn on desired effects layers.
That way you can have a more true "faux" relationship of angles.
(whatever that means :D)
