How to fade a person from a photograph?
Akbar Khan
on Oct 13, 2012 at 1:37:55 pm
Hello,
For the last couple of days I have been breaking my mind trying to find a way to fade a person from a photograph
Example
In this current video, Hermione Granger disappears from all the photographs(Deathly Hallows Part I).
Does anyone know a tutorial or a trick as to how I can achieve this?
I will be very grateful for your help.
Thank You
chris brett
Re: How to fade a person from a photograph?
on Oct 13, 2012 at 2:54:53 pm
Hi Akbar -
-- this is an easy one though if you have not done this before you will need to spend quite a bit of time reading up about it.....
1 ) Get the Photo graph ( that was n the shoot ) - take it into Photo shop and paint out the subject using cloning or whatever - this is so you have 2 versions - one with and one without subject.
2 ) take clip into AE and add the 2 PS stills as seperate layers.
3 ) track the 2 PS stillS to the picture frame in the moving shot and cross-fade from one to the other as desired.
All the best
Chris Brett /// U K
Tom Daigon
on Oct 13, 2012 at 3:51:37 pm
I would add that using the healing brush in conjunction with the cloning tool will get the results you want.
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
(Best viewed at 1080P and full screen)
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid
