Smoothing an abrupt camera panning?
JonZ MarZ
on Oct 8, 2012 at 10:17:08 am
I am trying to smooth out a shot where the camera pans in a landscape, but the camera stop very abruptly, I cannot reshoot the sequence again so I try to recover it to add a kind of smooth movement. I tried the warp stabilizer but it looks too strange.
I wonder if there's a good technique to make what I want happen.
Vishesh Arora
Re: Smoothing an abrupt camera panning?
on Oct 8, 2012 at 11:27:03 am
JonZ
You can try Time Remapping. Enable time remap for your footage and then make a key frame few frames before the End(or where there is a jerk). Now Easy ease the last two key frames and it will give you a smooth stop.
Vishesh Arora
VFX and Motion Graphics Artist
Films Rajendra
Blog:
http://digieffects.wordpress.com
Demo Reel(3D):
Dave LaRonde
on Oct 8, 2012 at 1:40:14 pm
I would only use Easy Ease on the FINAL keyframe. If you use it earlier, you'll get an unwanted change in speed.
Dave LaRonde
Former Sr. Promotion Producer
Vishesh Arora
on Oct 8, 2012 at 1:50:28 pm
Dave
You are right. Easy ease just on last key frame will give the best result :D
Vishesh Arora
Films Rajendra
Blog:
Demo Reel(3D):
JonZ MarZ
on Oct 8, 2012 at 6:29:12 pm
is that possible without time remaping thought? I've shoot in 24fps, slowing down the fps will worsen the effect to me.
Dave LaRonde
on Oct 8, 2012 at 7:54:17 pm
Well, we weren't commenting on the eventual quality of the work, just explaining the process to be used.
If AE can't deliver the quality you need, it's time to reshoot... or do the best you can with the cards you've been dealt.
Dave LaRonde
JonZ MarZ
on Oct 8, 2012 at 8:08:33 pm
Well people usually suggest the easy route when they don't have every infos. I can understand them, I often think there's only good one approach.
I can play with panning, by playing with the size of the video, the footage has a greater amount of resolution so I can play with some panning and zooming effect. I don't know if I could work on something around it.
