Alexa ArriRaw - Can't Import Footage as a Sequence in AE CS6
Steven Drypolcher
on Sep 22, 2012 at 2:16:27 am
I'm working with ARRIRAW footage which is recorded as a sequence of .ARI files. CS6 supports ARRIRAW, but it won't allow me to import them as a sequence. Sooo... I imported them all as individual stills, selected all of them in my project, clicked 'New Comp from Selection', and specified the Still Duration as 1 frame. Now this ALMOST worked, but the fact that I can't change it from Base 30 to Base 24 means that the each frame duration is too short for my 24fps composition.
I'm kind of between a rock and a hard place on this, so any advice would be appreciated! I either need to be able to import my .ARI files as a sequence, or I need to be able to change the Still Duration to Base 24.
Any advice would be much appreciated!
Vishesh Arora
Re: Alexa ArriRaw - Can't Import Footage as a Sequence in AE CS6
on Sep 22, 2012 at 7:06:27 pm
Mr. Drypolcher
In CS6 the option to change the Time code base is missing.
If you have CS5, then
Press " Cntrl/Cmnd + Alt/Opt + Shift + K" or go to File>Project Settings
There you can change the TIme COde Base.
You can buy a trial version if you don't have it with you.
Vishesh Arora
VFX and Motion Graphics Artist
Blog:
http://digieffects.wordpress.com
Demo Reel(3D):
