Bending Particular 90 degrees...like using air until it hits "the floor"
Max Jackson
on Sep 18, 2012 at 5:12:09 am
Hi CC,
I've got a situation where I'm trying to have a smoke effect cascade down a subject then hit a floor and change direction.
Is there an AE preset that can assist me with this?
I've got 'air' doing great stuff, and I've got 'bounce' creating the turn, but I can't create smoke in a turbulent web and bend it using the same particle engine at the same time.
What does one do when this happens?
Thanks for reading. :)
Tudor "Ted" Jelescu
Re: Bending Particular 90 degrees...like using air until it hits "the floor"
on Sep 18, 2012 at 8:44:27 am
You can try using a second particle generator or use a distortion technique like in this tutorial:
http://library.creativecow.net/articles/rabinowitz_aharon/CC_puppet_particl...
Tudor "Ted" Jelescu
Senior VFX Artist
Max Jackson
on Sep 18, 2012 at 8:52:43 pm
My character emitting the particles is standing still for the most part so this should work well I think.
Thanks for the tip!
