Render Layers Script
Josh Hamilton
on Sep 13, 2012 at 8:54:13 pm
I've been searching for prior posts on this so if anyone knows where to point me I can check that out too. Essentially I'm importing an XML to AE from FCP to key some interviews in keylight, after the keys are complete I attempted to run the Render Layers script to output the keyed layers as individual clips to then reconform in FCP. While it works, it also renders out the black before and after each layer. Is there something I'm missing that could help just render out what i need without the black handles lasting the length of the comp?
Thanks.
Josh
Josh Hamilton
Re: Render Layers Script
on Sep 13, 2012 at 9:05:07 pm
Duh, right under my nose, select Layer In/Out Range as oppose to Work area in settings for those other boneheads like myself.
