Particular Question
Max Jackson
Particular Question
on Sep 13, 2012 at 2:41:59 am
Hi, sorry if this is the wrong forum, but I am using After Effects.
I have this particle stream where it's pouring out like salt. I'm looking for two things to happen that I can't seem to alter.
1) I would like the particles to kind of curl up and whisk away like smoke and dust does with enough interference. I can use turbulence but it just seems to bend and twist the stream out of shape. I'm looking for random particles to curl up and disappear. Almost like an upside-down fountain.
2) In the scene these particles must hit a floor and curl up at a certain x-point, much more severe than merely pealing off. In addition to 1) I need them to react to a surface and float upward like dry ice.
If anybody has run into this before and can help point me in the right direction I'd appreciate it.
Thanks for reading :)
Vishesh Arora
Re: Particular Question
on Sep 13, 2012 at 6:36:41 am
Mr. Jackson
To create a smoke like dry ice, you can learn something from this tutorial:
http://ae.tutsplus.com/tutorials/motion-graphics/create-a-mysterious-smokey...
Hope this will help.
Vishesh Arora
VFX and Motion Graphics Artist
Blog:
http://digieffects.wordpress.com
Demo Reel(3D):
Max Jackson
on Sep 13, 2012 at 7:05:00 am
If somebody stumbles upon this forum thread I found the answer to question #2:
It's called Motion Path. Particular has a thing called motion path where you create a light and give it keyframes in a 'particular' path (har har) and then attach your smoke to this path like a null object and it travels like a motion guide. Way cool.
