How to move the crosshair/middle point from text
John Connor
on Sep 8, 2012 at 3:39:02 pm
How do I move that red crosshair to the center?
It happens when you created a text box that is too big for the text.
John Cuevas
Re: How to move the crosshair/middle point from text
on Sep 8, 2012 at 5:31:50 pm
Press "Y" that activates the pan behind/anchor point tool. Now you will be able to move the anchor point back to the center or the text. I think(don't have AE available right now) that if you hold down cntl it will snap into position, it does on the CS6 version.
Johnny Cuevas, Editor
Thinkck.com
"I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work."
---THOMAS EDISON on inventing the light bulb.
Vishesh Arora
on Sep 8, 2012 at 6:32:08 pm
MR. Conner
If you have older version of AE, you can try these steps:
1. Turn off your live update(near the search bar in layer panel). This will enable the wireframe of any object that you will try to move.
2. Now press "Apostrophe" or click on "Choose grid and guide option" which is in viewer near magnification ratio and choose Tile/Action Safe.
3. Now move your text layer the the center crosshair using the bisection point of the diagonals.
4. Now Press " Y " and move your anchor point to the center point of the frame.
Vishesh Arora
VFX and Motion Graphics Artist
http://digieffects.wordpress.com
Adriano Moraes
on Sep 9, 2012 at 7:12:14 pm
Hi there. All suggestions are spot on but if you want things to be more automatic and/or be able to do it for multiple layers at the same time you might want to check this one out:
http://aescripts.com/repositionanchorpoint/
Cheers.
ninguem
////http://cargocollective.com/ninguem/
